  • SN95 4.6L Mustang Tech
Help!!!!!!
  • Thread starter Thread starter cmb91LX
  • Start date Start date Aug 27, 2004
cmb91LX
432
Memphis
Aug 27, 2004
  • Aug 27, 2004
Help me out. The past few weeks I have been having a problem. Just like the other posts on here about the warm start ups except when I get in after stopping for a minute, as sson as I start it the guages ALL roll over and stick for a second then come back to normal. Is my PCM freaking out or what. It is the same needle sweep as if you would unplug the battery to reset the PCM. Is this a problem?
white99gt
4,649
stockbridge,Ga(near atlanta)
Aug 27, 2004
  • Aug 27, 2004
You have a power loss somewhere to the ecu..Check all your fuses and grounds first..
cmb91LX
432
Memphis
Aug 27, 2004
  • Aug 27, 2004
where would you suggest I start checking? Which location would be typical to exhibit this problem?
cmb91LX
432
Memphis
Aug 27, 2004
  • Aug 27, 2004
Forgive my ignorance BUT which fuses would be the likely culprit so I will know where to start? Is the ECU in the pass side kick panel? I am not very adept or have much experience with electrical gremlins
white99gt
4,649
Aug 27, 2004
  • Aug 27, 2004
Like i said .Check all the fuses..
The best ground to check is the one for the ecu (its behind it).
white99gt
4,649
Aug 27, 2004
  • Aug 27, 2004
Im not sure which exact fuses but check them all.One fuse box is under the hood drivers side..The second one is drivers side under the dash.
The ecu is on the passenger side kick panel..
cmb91LX
432
Memphis
Aug 27, 2004
  • Aug 27, 2004
thanks
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
K
Engine 2000 Mustang GT - Fuel issue post-blown spark plug repair
  • kenster1092
  • Feb 26, 2026
SN95 4.6L Mustang Tech Mar 10, 2026
kenster1092
K
H
Strange steering/brake issue
  • Haxmaster
  • Jun 2, 2026
SN95 4.6L Mustang Tech Jun 3, 2026
squeak93
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
