HELP
  • Thread starter Thread starter 88blkmustang
  • Start date Start date Dec 24, 2004
88blkmustang
pawling, ny
Dec 24, 2004
  • Dec 24, 2004
ok well i've been away at college and my dad was in charge of starting my stang to make sure it kept running and get the fuilds flowing well......he slacked off and my stang wasnt even touched in like a month and a half when i came back from school i tried starting it after i charged up the battery and no luck. i got the engine cranking over but it doesnt fire up. i know theres gas in the tank and i added prolly another gallon or 2 after it didnt fire up thinking it might be out of gas but.....no lucky i need some help i need to get my car started what should i do to get it running?
HISSIN50
34
129
Dec 24, 2004
  • Dec 24, 2004
do you have spark? FP?
i would get Jrichker's no start checklist and go to town.
good luck.
88blkmustang
pawling, ny
Dec 24, 2004
  • Dec 24, 2004
whats FP? and i dont know if i'm getting spark. i'm guessing i'm not getting spark if its not firing up thats the only guess i have but i dont know how or where to check the spark system like the coil or anything
frddriver
ontario,canada
Dec 24, 2004
  • Dec 24, 2004
FP means fuel presure, make sure your fuel pump is priming when you turn the key on!! you should be able to hear it.
RYC CUKR
1,437
Orlando
Dec 24, 2004
  • Dec 24, 2004
FP = fuel pressure.
There is a schrader valve on the fuel rail. It is on the passenger side fuel rail kinda of behind the alternator. You can put a fuel pressure gauge on there and check for fuel pressure.
Hissin is right look at jrichker's checklist. He has a lot of info on his site. Look him up by screenname and there is a link to his page in his sig.
HISSIN50
34
129
Dec 24, 2004
  • Dec 24, 2004
here is a link to Joe's list:
http://forums.stangnet.com/showpost.php?p=4858447&postcount=3
i would omit the first part about ignition interlock devices (bad or no signal to the solenoid).
check for spark and Fuel pressure and go from there. post what parts you dont get or are not sure of. that's why we are here (but it would take 10 pages to go through it all).
good luck.
88blkmustang
pawling, ny
Dec 24, 2004
  • Dec 24, 2004
thanks alot guys i'm gonna try that 2morrow
dastang2
2,020
tx
Dec 24, 2004
  • Dec 24, 2004
pull one of the spark plug wires and put a long screwdriver inside the boot and make sure it is touching the metal contact. the have somebody crank the car over while you hold to metal part of the driver to the header or intake or anything metal that is grounded. don't touch the screw driver to the metal, just barely hold it over the metal to see if a spark jumps over, it should be blue but and orange spark will run a car. it it sparks, then check the fuel pump inertaio switch. it is by the driver's side taillight in the trunk, behind the padding. the button on top should be pushed down but it might be up.
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 24, 2004
  • Dec 24, 2004
It is probaly a dead battery.
dastang2
2,020
tx
Dec 24, 2004
#10
  • Dec 24, 2004
  • #10
he said it cranks over, can't be the battery.
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
D
rpm goes up - car does not speed up.
  • dawakbar
  • Oct 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 27, 2026
nickyb
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
K
Engine Gt40p vs 180 procomp
  • Kleinjj27
  • Oct 27, 2026
Fox 5.0 Mustang Tech Tuesday at 2:05 PM
Kleinjj27
K
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
