Help!
  • Thread starter Thread starter smac61
  • Start date Start date Jun 11, 2005
smac61
294
SC
Jun 11, 2005
  • Jun 11, 2005
Driving to work Friday, after about 28 miles of normal cruise, I was coming out of a 45 zone, car was in third gear. I increase speed to 55, and just as the trans shifted into OD the car started to shudder as if it had a spark miss. Running pretty ragged for the next mile to work, and the check engine light came in. As I stopped I could hear what seemed to be valve tapping similar to what you would hear with low oil level (oil level and pressure were fine). Checked all the spark plug wires, no arc. Noticed that my wide band was showing a little lean (around 16), so tried adjusting the AFR with the PMS. I could tell a difference but the problem was not corrected. Pulled the codes and got a 65, bad act sensor. Replaced the ACT sensor today, no difference. The code 65 also returned.
I don’t know if the tapping started at the same moment that the car started to run rough. And although it started the moment the tranny shifted to OD, the condition is present in all gears and at idle. Don’t know if this means anything, but the tapping seems to be from the right side at the front of the valve cover which happens to be near the ACT sensor. Is there possibly something wrong with the #5 valves/rockers causing heat build up in the #5 runner (ACT location)? What the heck is going on?? Little help please!!
D
Daggar
3,902
  • Jun 11, 2005
The first thing that I would be looking at would be to ensure that the PMS is still securely attatched to the computer.
smac61
294
SC
Jun 11, 2005
  • Jun 11, 2005
Yeah, that did cross my mind, but I kind of blew it off since it has that bolt thing that secures it. Maybe the other side though, where it mates up with the engine harness. You're right, I should probably check it. That may explain the ACT sensor code, but not the tapping, right?
D
Daggar
3,902
  • Jun 11, 2005
The tapping can be explained by the 16:1 AFR if the PMS is doing screwing things. Lean fuel and some screwy spark tables is enough to make all the ticking noises you'd like.
smac61
294
SC
Jun 11, 2005
  • Jun 11, 2005
Ah yes, I see now. At idle I was able to bring the AFR down into the 12's and it seemed to start choking as I added more. Tapping was still there throughout the adjustments. I think I will pull those connectors and give them a fresh coat of grease just to be sure. If that doesn't do it, I guess I'm off to the mechanic. Thanks for the input!
smac61
294
SC
Jun 13, 2005
  • Jun 13, 2005
Update
For those interested......
Broken valve spring, #5 cylinder.
Curse
791
El Paso, TX
Jun 13, 2005
  • Jun 13, 2005
That’s interesting, the valve spring just gave up? Did you accelerate hard into OD? Well glad you found the problem.
smac61
294
SC
Jun 13, 2005
  • Jun 13, 2005
No hard acceleration at the time. Normal 5 AM commute. Probably the result of pokin it one too many times (3 years and 40,000 miles on the engine). Not that I would ever do that! I guess its just one of those things.
Curse
791
El Paso, TX
Jun 13, 2005
  • Jun 13, 2005
Yeah it happens Good luck getting it fixed and the car back on the road
smac61
294
SC
Jun 13, 2005
#10
  • Jun 13, 2005
  • #10
Thanks! Should be back on the road this afternoon. Taking the opportunity to have my AFR and 42# injectors installed since the intake is off.
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Oil burning on my recently buil 302
  • The blk67
  • May 15, 2026
Fox 5.0 Mustang Tech May 15, 2026
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Idles great, but stumbles when driving
  • Stang9050
  • Oct 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 8, 2025
Mcmahst
Engine Coolant boiling in hose?
  • Teen'93stang5.0
  • Jun 3, 2026
Fox 5.0 Mustang Tech Jun 8, 2026
Mustang5L5
