You might want to start a new thread. It sounds like you have an automatic, and since you jacked the thread, it will confuse people (I just had to re-read half of this since I couldnt figure out where this post came from - we were talking about a guy who swapped from AODE to T5).boostaddict5_0 said:Alright I got the bypass done so now the car is running, but the transmission won't go into any gear. I went thru all the gears and came up with nothing. I messed with the shifter cable. I put the shifter into drive and pushed the lever all the way forward and came back three clicks. If it's out of sync why does the reverse light come on? I'm really getting tired of this.
In your thread, post if you have an AODE after all. I WOULD NOT bypass the neutral safety switch on an auto - there is NO reason to do so.
Good luck.
(Before, as a bad habit, I was used to turning the switch all the way, then pressing the clutch in to start it .... except this time it was in gear + no NSS)
