  • 1994 - 1995 Specific Tech
HELP!!
  • Thread starter Thread starter sn-95matt5-0
  • Start date Start date Nov 7, 2006
sn-95matt5-0
170
  • Nov 7, 2006
i have some bad vibrations coming from the front end of my car i recently had it alined and it helped alot i also had the wheels balanced..but its still there....and also this morning the was a really viol;ent vibration coming from the rear end at about 35 mph
help me guys has this happened to any of you
sn-95matt5-0
170
  • Nov 7, 2006
has noone else had this kind of problem??
95strokerPSU
986
Sacramento from Philly
Nov 7, 2006
  • Nov 7, 2006
Are the bolts holding the driveshaft to the rear tight? I know mine like to come loose, so I check them everytime I'm under the car.
bill302
2,131
alabama,gadsden
Nov 7, 2006
  • Nov 7, 2006
as 95strokerPSU stated above check the drive shaft bolt and also make a visual inspection of the whole vehicle checking for loose bolts on wheels,axles driveshaft,check all bushings and bearings,shocks and mounts while inspecting tranny and motor mounts for damage ect....also checking tires and wheels for damage,cracks ect...and about the front end vibrations the front end shop should have diagnosed that problem for you. i would return the car to the shop and have them inspect the front end properly around here a front end alignment includes repairing and diagnosis of all or any worn or damaged parts that may cause problems with the front end and any reputable shops will not give you an alignment until all problem diagnosed are fixed...
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
J
Bad Vibration
  • jefffletch47
  • Feb 12, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 2, 2026
dgrinnan
D
W
2016 Mustang GT fuel tank leak
  • Waynetk16
  • Oct 8, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Oct 9, 2026
gkomo
