  • 2005 - 2009 Specific Tech
HELP!
  • Thread starter Thread starter wbstanggt
  • Start date Start date Oct 4, 2008
W
wbstanggt
17
Washington
Oct 4, 2008
  • Oct 4, 2008
I'm stuck at a friends house, and the stang won't start. I have a 2005 mustang GT that is having issues, you hear it trying to get started but it bogs out and dies. Since I'm almost 40 minutes from home I don't have my tuner with me. Guess I'm going to have to start bringing that with me. I've tried a few times to get it running but it keeps dying. Could a fuel filter really become clogged with only 38k miles? I've only used Chevron gas in it since I bought it new back in Nov 2004, and have pretty light modifications, as compared to a lot of people on here. IE air filter, custom x-pipe and flowmasters. I have had this issue once, but it started up within a few minutes, and never had the issue again. Any help would be appreciated.
hotrodnut
672
North Florida
Oct 4, 2008
  • Oct 4, 2008
Maybe the Fuel Pump Shut-off Switch needs reset. It's located in the Drivers side footwell, by the hood release. The manual says turn the key off, check for leaks, reset the button, turn the key on, check for leaks wait a few seconds then turn it on and check for leaks again. Then try to start it.
DarkFireGT
Playing with my wife's really makes me want one.
692
10
89
East Moline, IL
Oct 4, 2008
  • Oct 4, 2008
If that doesn't work, unhook the battery for about 20 minutes and try reconnecting it and starting it then. One of the two should fix ya up.
W
wbstanggt
17
Washington
Oct 4, 2008
  • Oct 4, 2008
alright, tried the fuel pump reset, no luck there, hope the battery deal works, the motor starts cranking and I've tried feeding it fuel, it chugs a lil more and sounds like it's about to catch,then dies...
NastyStang113
1,567
Florida
Oct 4, 2008
  • Oct 4, 2008
Hmm ... I'm signing on for this.
UrbanRedneck
173
  • Oct 4, 2008
It has gas in it right?
See if it is getting fuel pressure. There should be a shraeder valve on one of the fuel rails, turn the jey on and stick a key in there like you're letting air out of a tire. AFuel should spray out strong. This is not an acurate test, but ti could point you to whether or not you have fuel at least.
bigcat
start with the upper hole, and if more traction is
May 1, 2005
3,015
7200 feet
Oct 4, 2008
  • Oct 4, 2008
3V motors dont have a schrader valve. they are a returnless style fuel system.
W
wbstanggt
17
Washington
Oct 7, 2008
  • Oct 7, 2008
alright, the battery thing worked, although the motor was still bogging pretty bad, I was able to keep the rpm's steady for a good 10 minutes before driving it off. I've still got the problem when starting it up and going, however. Once it's running it's no issue. It's simply a matter of keeping the rpm's up for about 30 seconds during the initial warm up. The neighbors are really loving me now. Gonna look at it next time I get a chance, I've reflashed it with the brenspeed tune I have, and I have no reason to suspect it to be a bad tune, since I've been using that for over a year. Maybe an O2 sensor? I dunno... guess I'll plug in the Xcal this evening and find out what it says. Thanks so far for the help.
whyask
735
Sacramento
Oct 7, 2008
  • Oct 7, 2008
Reload the stock tune. Call brenspeed and have a new tune resent.
SpartaPerformance
2,517
61
89
Long Island NY
Oct 7, 2008
#10
  • Oct 7, 2008
  • #10
+1 sounds like something has gone wrong with your tune....or the tune has just now affected something.
Art161
130
San Francisco
Oct 8, 2008
#11
  • Oct 8, 2008
  • #11
I think that the fuel filter is supposed to be changed every 30,000 miles. It's not the gasoline that necessitates the change. It's the crud that accumulates in the gas stations' tanks. I think the station pumps have filters, but some crud could still make its way into your gas tank, and then to you car's fuel filter.
Mr_Q
721
Burbank, CA
Oct 8, 2008
#12
  • Oct 8, 2008
  • #12
Yeah fuel filters are not for filtering the gas...it's for filtering the BS that's in most stations tanks which happens to be IN the gas, heh.
Running lower octane gas does not make your filter crud up sooner than higher octane as some insta-lube shops might try to tell you. (my comments are nearly irrelevant to the topic though...wth?)
ptfoxbdy89
137
Memphis Tn.
Oct 8, 2008
#13
  • Oct 8, 2008
  • #13
hey my 05 gt just had the same problem except mine was just a bs chip installed on the car before i bought it.. i just had them take it out and put in a stock one no problems as of yet.. im looking for a replacement cai and tuner now..
Khyron
68
Lincoln, NE
Oct 8, 2008
#14
  • Oct 8, 2008
  • #14
Check all your vacuum lines as well. Make sure nothing has come loose. It sounds like there could be a vacuum leak somewhere causing you to lose pressure.
F
2004 Mustang GT – Fuel Pump Not Priming
  • Fayio
  • Apr 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Apr 27, 2026
n0v8or
N
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
G
Persistent P0102 and limp mode
  • Godless
  • Oct 30, 2025
2005 - 2009 Specific Tech Nov 11, 2025
Godless
G
L
1997 V6 Starting issue
  • leanzik04
  • Mar 20, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 20, 2026
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
SN95 V6 Mustang Tech May 22, 2026
PNN
P
