HELPS Help motor shaking
  • Thread starter Thread starter 89saleenclone
  • Start date Start date Jul 1, 2004
89saleenclone
San Gabriel, California
Jul 1, 2004
  • Jul 1, 2004
Everyone told me it was most likely the driveshaft is bad so I just got and installed a new ford racing driveshaft. BUT its still doing it. I recently replaced the clutch cable for 2nd time in 10 weeks. So I think it might be the clutch, BUT I really don't know. CAN SOMEONE PLEASE HELP I'M LOST. By the way the clucth was installed about 12 weeks ago.
PLEASE HELP
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
Jul 1, 2004
  • Jul 1, 2004
check your balancer
RyanSG
286
Allentown, Pa
Jul 1, 2004
  • Jul 1, 2004
does the motor shake when it's out of gear? Even if you just rev it? If it does and it sounds liek it's the balencer. Whatever you do if it is the balencer DON'T RUN THE MOTOR! You'll damage the crank if not and probebly will damage other things as well.
I
iwashmycar
20+ Year Stangneter
Apr 7, 2004
1,236
Columbus, Ohio
Jul 1, 2004
  • Jul 1, 2004
Yep a bad balancer can really mess some ***** up.
89saleenclone
Jul 3, 2004
  • Jul 3, 2004
It dosen't shake when the car is out of gear. And I can hear a very bad metal to metal sound comming from what I think is the transmission area.
I wash my car is that hits4pay real???????
dastang2
2,020
tx
Jul 3, 2004
  • Jul 3, 2004
try motor mounts
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
Jul 3, 2004
  • Jul 3, 2004
What is this, a guessing game?
List the symptoms as best you can, and then maybe we can point you in the right direction. Randomly guessing/changing parts is expensive and a waste of time.
dastang2
2,020
tx
Jul 3, 2004
  • Jul 3, 2004
he said he heard something like the tranny hitting some metal and also said something about it not doing it when not in gear so that pretty much narrows it down some to mounts
89MustangGX
Jul 3, 2001
10,262
Mill Creek, WA
Jul 3, 2004
  • Jul 3, 2004
Yeah...that was after with no description multiple people agreed he has a bad balancer.
I want to know if it's while driving or sitting still? Does it change with engine RPM or speed? Is it really a vibration, or just noise?
There's alot more info that can be useful. It may very well be mounts, but it still seems like a guess at this point.
HISSIN50
34
129
Jul 3, 2004
#10
  • Jul 3, 2004
  • #10
ill take a stab at it. it is something in the motor or drivetrain.
seriously, as Adam said, we need every bit of info you can give. does it vib at idle. how about when you rev it in neutral? same two questions but in gear this time.
and when actually driving?
metal to metal *COULD* be as simple as the exhaust hitting the DS (clearance issues or MM or TM). the alum DS is bigger in diameter than the stocker.....
dont act on this - it is just info and things i would try.
follow Adam's sage advice.
dastang2
2,020
tx
Jul 3, 2004
#11
  • Jul 3, 2004
  • #11
anyways i was just saying to check the motor mounts
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Electrical Lincoln Mark VIII Replacement Fan Motor
  • AeroCoupe
  • Sep 26, 2026
Fox 5.0 Mustang Tech Sep 26, 2026
AeroCoupe
T
Need help with 302 swap
  • thxmxrgx
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 24, 2026
thxmxrgx
T
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
D
Mustang not starting
  • Dawry Ramos
  • Sep 12, 2026
  • 2015 - 2023 Specific Tech
2015 - 2023 Specific Tech Oct 3, 2026
Dawry Ramos
D
