coolent temp is on the front driver side of the lowerintake manifold, what kind of ignition is on the car is it msd ?
stock ignition
Check out the Surging Idle Checklist that's found in the Useful Technical Thread Index that's stickied at the top of this forum.
you put down you have a egr delete, did you also buy a egr simulator? if not go on ebay and order one, this will make your car do exactly as you are describing.
i pulled the codes last week
this is with the car warmed up
21 engine coolant temperature (ECT) out of self-test range
94 torque converter clutch solenoid circuit failure
44 air injection control system failure
31 egr positioner sensor below minimum voltage
77 brief wide open throttle not sensed during test
67 neutral/drive switch circuit open
also did a cyl balance test and i got a 9
