HI flow fuel pump probs.
  • Thread starter Thread starter dre0011
  • Start date Start date Jul 26, 2005
D
dre0011
10
  • Jul 26, 2005
just installed a hi flow fuel pump in my 90 gt and now when i make right turns the gas sloshes away from the pump and the car stalls...did i do somthing incorrectly... or is there a fix for this???
wyominghotwheel
156
Insanemustangs
Jul 26, 2005
  • Jul 26, 2005
sounds to me like something isn't right..........i have never heard of this before with installing a fuel pump.........are you sure it is moving completely away from the fuel pump suction? I would drop the tank and look at it again,,,,,,,,,,may just be a connection issue with the wires......
hotwheels of insanemustangs.com
bgjohnson
963
johnston,iowa
Jul 26, 2005
  • Jul 26, 2005
oh, make sure the wires aren't arcing in the gas tank, i've heard it happen exactly how you described, either that or your internal baffle has broken away from the tank. but definately pull the tank and check it out!
L
luckythirteen13
648
Anaheim, CA
Jul 26, 2005
  • Jul 26, 2005
i had the same problem with my ranger. when i put in a larger tank then factory, every time the tank was low the car would sputter and loose power when making left turns fast. since you replaced the pump and not the tank i would say its possibly an electrical issue since it just started when the new pump went in. check to make sure its not a baffle though just to rule that out
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
  • Mindseye007
  • Aug 16, 2026
Mindseye007
