Hi Flow fuel pump
  • Thread starter Thread starter DmnStr8
  • Start date Start date Aug 13, 2005
DmnStr8
NH
Aug 13, 2005
  • Aug 13, 2005
Recently I have had an issue with my car stalling out and not wanting to start back up. The problem has gotten so bad that I'm at wits end and I am going to have it towed to my mechanic to see if he can help. One of the issues is that it may be the fuel pump starting to go. If thats the case I was thinking now might be a good time to have an after market fuel pump installed. So I have a few questions.
Is this wise? My engine is stock and I have a stock fuel pressure regulator. I know this basically won't do anything but I figure it will be a mod that will be there in the future when I do need it and since I will be having the fuel pump done I might as well upgrade right?
What should I look for? I want the ability to grow into this pump but I don't want to buy something thats too big for the car.
Thanks
CRASH7772
401
NH
Aug 13, 2005
  • Aug 13, 2005
Your aftermarket options are 155lph, 190lph, and 255lph. If your staying N/A then I would probably go with the 190lhp, 255lph with forced induction but both are about the same price. It's not a bad idea to get a FPR as the stockers can be off somewhat. With the larger pump the extra fuel will get sent back to the tank and the pump will have less strain on it when the demand is there.
vristang
4,933
101
124
Seattle
Aug 13, 2005
  • Aug 13, 2005
I will vote for a 190lph. Excess flow should be able to run back to the tank.
Are you having the shop do the installation (assuming that's what the prob is)? Or just the diagnosing?
vristang
4,933
101
124
Seattle
Aug 13, 2005
  • Aug 13, 2005
Forgot I had this info.
Ford EFI Options___80% of Max___80% of Max
110lph_____________240___________200
155lph_____________340___________280
190lph_____________420___________340
255lph_____________560___________460
These recommendations are based upon running at 80% of the pump capacity to improve the pumps reliability.
So, on second thought a 155lph could be just fine for you for a while.
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
If comfy wrenching, doing a pump is no biggie.
David (5spd GT) has a write up on doing one, IIRC. Might be worthwhile to search his posts and read up.
When doing a pump, getting a filler pipe-to-tank grommet is a good idea (20 bucks).
Pump suggestions are right on. A 190 should be plenty (stock on an '87 is 88 LPR IIRC) if doing bolt ons.
Good luck.
DmnStr8
NH
Aug 13, 2005
  • Aug 13, 2005
Probably going to have the shop do the diagnosing and possiably the install if the pump is the issue. I know the guys and they treat me well. Plus I don't have a spot I could do the change.
Any brand recommendations?
HISSIN50
34
129
Aug 13, 2005
  • Aug 13, 2005
Walbro is oem and good stuff IMHO.
Half the 'other' brands out there are repackaged Walbros.
Good luck.
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
J
Having fuel issues
  • Jbands2v
  • Nov 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 2, 2026
LILCBRA
  • Mindseye007
  • Aug 16, 2026
Mindseye007
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Fox Fuel Pump Issues After Replacement/Upgrade
  • Ryu
  • Jun 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
Ryu
