High RPM roller lifters
  • Thread starter Thread starter Shaolin Crane
  • Start date Start date Dec 25, 2010
1 of 2 Next Last
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 25, 2010
  • Dec 25, 2010
What are you guys using for 7000rpm+ Hydraulic roller lifters, seems most of the OE style lifters are just stock replacements and not for an upgrade.
I was going to purchase some lunati lifters but seems they have been discontinued.
robo
132
cleveland ohio
Dec 26, 2010
  • Dec 26, 2010
i've got a 347 with a hydraulic roller from cam motion. gt-40 heads, cobra manifold, 65mm tb etc...
i'm currently using ford replacement roller lifters.
i'm going to go with a high rpm upgrade. trick flow "r" heads, edelbrock victor 5.0 maifold, large tb etc....
my engine builder suggested i switch to a solid lifter as i plan to spin the engine to 7000 or so.
i'd look into a solid lifter if i was you. at least discuss it with your machinist/engine guy.
mattmcdan
176
Okeechobee, Florida
Dec 26, 2010
  • Dec 26, 2010
I use a set of link bar Comp Cams in my 408. PN CCA-8931-16. My 351 is a non roller so you may need a different part number. But they are high rpm non pump up lifters.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 26, 2010
  • Dec 26, 2010
7000rpm is fine for a hydraulic setup. I know they make lifters that will go there no problem, they are also crazy expensive and would be cheaper to go solid roller. However, i dont want the added maintenance of a solid roller. Nor do I want the reduced driveablity with them either. If this was a 351w or an aftermarket block i would. But on a 420rwhp 347, hydraulics will fit the bill just fine.Not to mention solid would reduced the life of a stock 8.2 block even more. This thread was for a decent priced alternative.
robo
132
cleveland ohio
Dec 26, 2010
  • Dec 26, 2010
why will a solid lifter shorten the block life?
i'd argue that 7000 rpm with a 50oz. imbalance would shorten the block life.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 26, 2010
  • Dec 26, 2010
First the motor isnt a 50 imbalance, second solid rollers transmit ALOT of vibrations into the block. When that cam is moving at high speeds and its metal to metal its acting like a big tuning fork, and the cam WILL be flexing even with a roller setup, all that is transmitted into the block.
robo
132
cleveland ohio
Dec 27, 2010
  • Dec 27, 2010
Shaolin Crane said:
First the motor isnt a 0 imbalance, second solid rollers transmit ALOT of vibrations into the block. When that cam is moving at high speeds and its metal to metal its acting like a big tuning fork, and the cam WILL be flexing even with a roller setup, all that is transmitted into the block.
WOW! i didn't think you had the bottom end "zero" balanced (most folks don't on a stock block / crank / rod setup and that's why i said 50 oz. imbalance) and unless you did, you will have problems keeping a stock block together at 7000 rpm!
are you sure you know what you are talking about? maybe you should seek the help of a knowledgeable machine shop.
tunning fork ??????? cam flexing??????
let me sum it up for you....... STOCK BLOCK.......7000 RPM! forget about the cam flexing. camshaft harmonics will be the least of your problems.
srtthis
the guy doing it does every local racers rear end
5,129
1,666
204
Maryland
Dec 27, 2010
  • Dec 27, 2010
pure street guys spin the stock lifters to 9000+ rpms... as per ryan hecox out of the box into the motor...
robo
132
cleveland ohio
Dec 27, 2010
  • Dec 27, 2010
what does the rest of the valvetrain consist of? shaft mount rockers, titanium retainers? what spring pressures?
i'm genuinely interested.
the op is worried about camshaft harmonics and i think that will be the least of his problems. i'd be more worried about crankshaft harmonics if he has a 50 oz. imbalance reciprocating assembly and a stock block at high rpm.
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Dec 27, 2010
#10
  • Dec 27, 2010
  • #10
is the rotating assembly 0 balanced? I bet it is a 28oz imbalance.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 27, 2010
#11
  • Dec 27, 2010
  • #11
Yep, 28oz
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 27, 2010
#12
  • Dec 27, 2010
  • #12
Yep, but they only keep on it for a 10 seconds, and swap them out after every few passes.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 27, 2010
#13
  • Dec 27, 2010
  • #13
I dont know where i said stock internals. Second the "0" was a typo, allow me to fix that.
You're right i dont. I'll just forget about modding my car at all
I dont know why i even bother here anymore.
mattmcdan
176
Okeechobee, Florida
Dec 28, 2010
#14
  • Dec 28, 2010
  • #14
Comp Cams link bar lifters... It wasn't just a suggestion. They ARE high RPM hydraulic roller lifters. you may have overlooked my original reply with the dip**** that went off topic.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 28, 2010
#15
  • Dec 28, 2010
  • #15
Yeah, ive seen them, those were some that i considered overpriced and would be better to go solid for the price.
I think i'm going with these
COMP Cams 851-16 - COMP Cams High Energy Hydraulic Roller Lifters - Overview - SummitRacing.com
mattmcdan
176
Okeechobee, Florida
Dec 29, 2010
#16
  • Dec 29, 2010
  • #16
quit pinching pennies you ol grouch!
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Dec 29, 2010
#17
  • Dec 29, 2010
  • #17
Im trying to avoid the "Just Bug" This is the reason why my old engine was put on hiatus for so long. And subsequntly had to be sold since it was never finished. And im hesitant to drop a **** load of money on a stock block 347. When i go aluminum I will though
2000xp8
SN Certified Technician
Aug 8, 2003
8,047
1,637
194
NJ
Jan 6, 2011
#18
  • Jan 6, 2011
  • #18
I was picking my buddies brain at his shop today(plenty of pushrod experience, been doing it long enough that some here weren't even born yet) on the lifter and high rev engine topic, especially since there seems to be quite a few interested in it these days.
He feels it can be done, but not on any type of reasonable budget. His claim, ya it can be done, but to do it right you will spend far more than it's worth, cap the rpm at 6500 or so, and be happy, any higher isn't worth the money or headaches.
I gathered a bit of info from him.
First off, he feels link bar lifters do little good other than let you retrofit them in blocks that can't use the spider.
He's tried it every which way, including custom modded lifters, rhoades, comp cams (who grinds all his custom cams), and solids.
None of which he has been thrilled with (on stock blocks), especially on cars meant to do anything other than the quarter mile.
As far as solid setups, he's definitely anti on anything other than a race block. Last time i personally saw it attempted, it was on a B block, and it just wouldn't stay together properly for long, the high rpm didn't destroy it, but caused issues.
Switched to an R, and it was and still is fine as of today (same rotating assembly).
Not my thoughts, just someone with some experience's opinion, take it or leave it.
I've known him for almost 20 years now, and i'd say if you came to him with 7000rpm in mind, he'd either talk you out of it, or refuse to be a part of it.
I trust his opinion, but that obviously doesn't mean you have to, just some friendly thoughts on the topic.
Me personally, my last engine ran right to the rev limiter, and that was good enough for me.
liljoe07
5 Year Member
Feb 18, 2009
1,622
363
124
Cartersville,Ga
Jan 8, 2011
#19
  • Jan 8, 2011
  • #19
I would at least spend the few extra dollars and get the short travel lifters. Better RPM capabilty.
COMP Cams: Short Travel Race Lifters; Ford Small Block
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Jan 16, 2011
#20
  • Jan 16, 2011
  • #20
Hmmm didnt see these posts.
Good for some is not enough for others
Not saying its not enough, seems there is alot of disagreement on lifters between lots of shops, my builder would ONLY run solid or flat tappet, Ed at FTI said anything above 6250 he would run link bars. However this is my goal for the engine and I was looking for different possible lifters.
I didnt see those, I was given a good price on some Morel Link Bar lifters however from Ed at FTI.
1 of 2 Next Last
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
C
Flat tappet to roller lifters--older block
  • chazmanaz
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
Holley High-ram tuning settings
  • spencergt66
  • Apr 1, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jun 19, 2026
spencergt66
Autolite 3925 discontinued?
  • 387lx
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2026
Mustang5L5
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
