High volume or high pressure?
  • Thread starter Thread starter satanas
  • Start date Start date Apr 9, 2008
satanas
156
Arizona
Apr 9, 2008
  • Apr 9, 2008
I have my engine out and I have a question, Should I replace my oil pump its the original oil pump.whats a good oil pump?I hear melling has good pumps. Not sure what the difference between the high volume and high pressure.What the pros and cons. i have a 7 qt oil pan from canton.
Maryland Stang
1,656
30
39
Greenville, NC
Apr 9, 2008
  • Apr 9, 2008
Given the RPM limitations of the heads and cam I see no reason to put anything but the stock type pump in. It's always a good idea to replace a high mileage pump when the opportunity arises.
satanas
156
Arizona
Apr 9, 2008
  • Apr 9, 2008
Even If I have a Supercharger that feeds of the engine oil?
LiquidGT
368
Near STL hell
Apr 9, 2008
  • Apr 9, 2008
The HV pump will wear out the cam gear faster, I wouldnt use it on a street car, its good for a race engine that gets rebuilt often.
Plus you have a 7qt pan so you shouldnt have to worry about the pan drying out at higher RPM.
satanas
156
Arizona
Apr 9, 2008
  • Apr 9, 2008
Thanks LiquidGt. I guess I'll save me some money on the pump.I''ll get the stock replacement.
allballsmustang
174
Lehigh Valley, PA
Apr 10, 2008
  • Apr 10, 2008
i have always ran the high volume pumps on all my cars without a problem... i think its just a matter of personal preference...if i was going to install one on a forced induction application i would deff use the high volume because the charger or turbo is stealing oil flow from the engine to lubricate itself..
jim
LiquidGT
368
Near STL hell
Apr 10, 2008
  • Apr 10, 2008
^I'm not the foremost expert on superchargers, but a HV oil pump could suck the oil pan dry at prolonged high RPM. Then the supercharger trys to pump its own oil out the dry pan... and then you know.
But you have a 7 qt pan and not the stock one, so its less likely that would happen. (With HV or standard volume) I just dont like the cam / distributor gear wear idea.
Here's is an article in 5.0 Mustang on page 124. They're putting together a Griggs road course engine.
"A Melling M68 standard-volume, standard pressure oil pump is used because the high volume pump chews up the cam gear and distributor. With the rpm and bearing clearances in an Al engine, more oiling isn't necessary. If extra coolers, lines, and fittings (for the coolers) are on the chassis, then Griggs would use a standard-pressure high volume pump"
allballsmustang
174
Lehigh Valley, PA
Apr 10, 2008
  • Apr 10, 2008
ive always run my high volume pumps with a stock sump pan and never had problems with sucking dry...id have to find out the exact specs, but i would be willing to believe that the melling high volume pumps dont pump insanely more than the regulars which is why you can probably get away with it... id be curious to see exactly how much flow it would require and how long of a runtime you would need to actually wear out the cam gear with oil?
satanas
156
Arizona
Apr 10, 2008
  • Apr 10, 2008
so you guys recomend the HV pump or stock pump with my supercharger set up?
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Apr 11, 2008
#10
  • Apr 11, 2008
  • #10
What was the oil pressure before installing a blower? The blower alone is not likely going to justify a high volume pump, even on a used engine. Chances are good that the bypass valve is going to be what limits pressure anyway.
LiquidGT
368
Near STL hell
Apr 11, 2008
#11
  • Apr 11, 2008
  • #11
SB fords never had any oiling problems, I dont think the blower would cause a significant oil pressure loss, the oil line on the blower is small and it returns back into the oil pan.
Maryland Stang
1,656
30
39
Greenville, NC
Apr 11, 2008
#12
  • Apr 11, 2008
  • #12
I saw the blower in your sig when I recommended the standard pump. There is plenty of additional capacity in the stock pump to support the blower. I would imagine the oil needs of the blower are along the lines of the needs of a couple of rocker arms. Anyway, did the blower manufacturer recommend anything but the stock pump?
satanas
156
Arizona
Apr 11, 2008
#13
  • Apr 11, 2008
  • #13
no they didn't say anything about oilpump.
battyice
153
West Chazy, NY
Apr 11, 2008
#14
  • Apr 11, 2008
  • #14
What are you running for bearing clearances?
Hack
1,945
Minneapolis
Apr 11, 2008
#15
  • Apr 11, 2008
  • #15
Exactly! If you are using stock standard clearances, run the stock pump! Run the correct pump for the application.
satanas
156
Arizona
Apr 11, 2008
#16
  • Apr 11, 2008
  • #16
yes I am running stock clearenses
talladam
50
Monroeville OH
Apr 11, 2008
#17
  • Apr 11, 2008
  • #17
I've always ran high volume pumps as added protection in any motor i've rebuilt-freshened. If I was running a motor with loose bearing clearances (race, hi rpm, rebuilt yearly) I'd run a high pressure/high volume pump. But for a mild race/street car it'd be a high volume, esp. with forced induction oil needs.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Nov 1, 2026
manicmechanic007
P
Weird Voltage & Oil Pressure Gauges
  • PNN
  • May 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech May 22, 2026
PNN
P
