Here's my combo:
Originally C-code 289
Bored .030 over, 302 crank, 306ci total
Edelbrock Performer intake, Carter AFB carb
Hooker headers with 2" duals and h-pipe, Dronemaster Delta 40's
Pertronix Ignitor solid-state ignition, 45k volt coil, 8mm Pertronix plug wires
Stock cam, original heads
160.3hp @ 4300
229.5tq @ 3100
A/F went on a straight line from 14:1 @ 3100 to ~12.5:1 @ 4950
Measured on a Dynojet, corrected to SAE standard.
I think there's more power on this combo. I learned at least where the gains are to be had.
-The air filter's been on there for 4 years. Only has 1800 miles on it, but it has a lot of varnish from evaporated fuel
-Solid fan is mounted on a spacer sans clutch, grabs a lot of air
- Carter carb - can't remember what the CFM #'s are on it, but I seem to recall it's only 425cfm or so. The lean A/F #'s give me pause there, though. I'm going to have to find the build sheet for the motor.
I don't need a whole lot of power, but I think I'd have another 20hp in it with just the first two, easy.
What say you?
160.3hp @ 4300
229.5tq @ 3100
What say you?
