I have a 289 running two 4 bbl holleys - 390 cfm each. The engine has maybe 30k miles on it, and have never had a problem up until recently. Anyway, the rear carb is dripping a pretty steady amount of fuel upon startup, and it is running pretty rough.
I pulled the air cleaner off to see where the drip was coming from, and the whole top of the carb was wet with fuel, making it hard to tell what was leaking. I'm thinking some seal must have a hairline crack or something because I drove the car around a few weeks back, and after it warmed up, it ran smooth and the drip seemed to stop.
I called a local shop that deals with old Fords exclusively and he indicated the carbs were overdue for a rebuild, and estimated $400 or so, plus a tune up charge. Is there anything simpler that might remedy this problem? Does a rebuild sound reasonable for an engine with 30k miles on it over maybe 6 or 7 years? Would it be worth it to just get new or rebuilt carbs instead of paying someone to rebuild these? If so, any suggestions on other carb brands or sizes?
Thanks for any help or suggestions on this...
