holley fuel pressure regulator
powernexcess
24
joplin, mo
I've got a holley fuel pressure regulator that I installed the instructions say you can set the fuel pressure from 35-65psi. I'm trying to set the fuel pressure with vacume off at 38 psi but the fuel pressure regulator won't go any lower than 40 psi. Does anybody have any ideas that could help.
They are not a waste of money. What if his set up requires something different than the stock setting. Not all Mustangs/cars require the same things. Different combos, different rules.
Powernexcess, how are u checking the pressure? (I mean are u sure that ur guage is correct?)
I've only got the one gauge last time I used it the gauge worked great. I wish I had another gauge to make sure my gauge is good. I thought maybe the fuel pressure regulator adjustment screw was off or something.
Shouldn't be but is completely possible. Most companies (holley is a great fuel part company) test their products many times for quality contol. Best bet is to call their support line and see if they have any ideas. Are u plugging off the vac line as well? this could mess with things.
Ya I pluged the vacume line, but didn't seem to make a diffrence. I'm taking it to get dyno tuned in the morning so I hope this does not cause a problem. Event at 40 psi the car does idle better than with the oem regulator.
If he needs one or his tuner needs one .ITS A TEMP FIX,if his tuner is suggesting he needs one ,HE IS A HACK tuner...Bumping up the fuel pressure by the regulator will be take out by the ecu after a few miles of driving it..
ANY stang that is tuned PROPERLY aka chip,doesnt need the fuel pressure adjusted.. As long as the regulator is doing its job,anything else can be tuned out with a chip.
Personally,You should go to bigger injectors and dump the fmu(which you probably have).THen get it properly tuned.
If you tune a supercharged car VIA the fuel pressure regulator ,plan on it running LEAN after driving it awhile..But its not my money going down the drain.
