Holley powervalve
  • Thread starter Thread starter hookups333
  • Start date Start date Jan 5, 2006
H
hookups333
154
Jax Florida
Jan 5, 2006
  • Jan 5, 2006
How do you change a powervalve on a holley. Its a 600 cfm 4v if that helps. All i know is that it is in the primary bowl area but i dont really know how to take it out from there.
302 coupe
1,952
Macon, Ga.
Jan 5, 2006
  • Jan 5, 2006
remove the front fuel bowl, remove the metering block from the main body, remove powervlave by putting a 1" wrench on it and turning counterclockwise. Install is reverse of removal. Tis very easy.
H
hookups333
154
Jax Florida
Jan 5, 2006
  • Jan 5, 2006
how do you remove the metering block?
302 coupe
1,952
Macon, Ga.
Jan 5, 2006
  • Jan 5, 2006
it just comes off. It goes between the fuel bowl and main body, the 4 5/16" screws that hold the fuel bowl on also hold the metering block on. Once they are removed, the fuel bowl comes off, then the metering block can be removed. It might be kinda stuck to the main body, maybe have to gently pry just a little. You might need to get new gaskets in addition to the power valve in case they break during removal. Normally the good blue gaskets, or the red gaskets, hold up fine.
H
hookups333
154
Jax Florida
Jan 5, 2006
  • Jan 5, 2006
alright thanks alot.
H
hookups333
154
Jax Florida
Jan 5, 2006
  • Jan 5, 2006
worked like a charm its all better now. Thanks for your help.
302 coupe
1,952
Macon, Ga.
Jan 5, 2006
  • Jan 5, 2006
A
Old Holley head identification???
  • Ar15cobra
  • Jan 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 27, 2026
AeroCoupe
D
Fuel Erratic Fuel Pressure 1985 GT
  • DienstXIV
  • Jan 14, 2026
Fox 5.0 Mustang Tech Jan 16, 2026
AeroCoupe
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
Engine Contour fan CFM
  • Mustang5L5
  • Apr 6, 2026
Fox 5.0 Mustang Tech May 22, 2026
qikgts
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
2K
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
