home alignment
  • Thread starter Thread starter 67GTA-FB429
  • Start date Start date Jan 7, 2004
67GTA-FB429
777
Tri-Cities, Wa
Jan 7, 2004
  • Jan 7, 2004
I know that I have read somewhere in the forums that some members do their own alignments at home. How are you doing this and what special tools do you need??
I finally finished installing new control arms, tie rods, sway bar, springs, shocks and shelby drop and I would like to get everything setup for a test drive after all of the dang snow in Washington melts (-14F on Monday).
Any help is appreciated.
66P51GT
721
Cerritos, CA
Jan 7, 2004
  • Jan 7, 2004
Car Craft has a "Best of Tech" magazine at the news stand this month that has a great article on at-home alignments.
coolblue65
1,224
Algonquin, IL
Jan 7, 2004
  • Jan 7, 2004
I have aligned my car at home twice, its actually pretty easy if you have the guage for camber & caster and the patience. Toe you just need a tape measure.
My step-dad bought a guage from some where for about $50-70, I can not remember where...possibly J.C. Whitney. We made some very simple homemade slide plates, and we were set-I already had plenty of shims. It took about an hour or so.
If you find the guage for cheap enough its worth it.
dodgestang
1,360
Cecil County, MD
Jan 7, 2004
  • Jan 7, 2004
ftp://ftp.team.net/autocross/align.car
U
usedtobe 67p51d
208
let's tear up golfcourses and build race tracks!
Jan 7, 2004
  • Jan 7, 2004
this was a question I was pondering. If you only adjust caster, will it effect toe or camber? does anyone know?
BobV
20+ Year Stangneter
May 18, 2003
474
Leavenworth, KS
Jan 8, 2004
  • Jan 8, 2004
I do all my own alignments at home. Spend $65 for a decent caster/camber gauge, and you're 90% "there". Not hard, just takes time.
Remember, alignment techs get paid by how many they do, not how well they do them. Most "specs" are +/- 1/2*, meaning your car can be up to 1* different from side-to-side and still be within THEIR "spec". You can get to within 1/8* at home with some patience.
My "Home Alignment" method: http://www.gt350clone.com/alignment.htm
Changing caster will change toe, and usually changes camber also.
67GTA-FB429
777
Tri-Cities, Wa
Jan 8, 2004
  • Jan 8, 2004
Thanks guys.
66candy
17
The Netherlands
Jan 9, 2004
  • Jan 9, 2004
Homemade alignment tool....
I made my own alignment tool. I did some math and came with this Every turn of the knob is 1/2 degree. I checked camber with a computer alignment I had done some months ago and it was within 1/4 degrees! So not a bad job for a homemade device.
Erwin, The Netherlands
01GTCONVT
50
Pryor, OK
Jan 9, 2004
  • Jan 9, 2004
This link will get you started; http://geocities.com/a65ragtop/VM_FAQ/miscellaneous/alignment.html
I did this on a 70 convert with neg wedge kit. Decided on the alignment numbers I wanted +1 caster, -1/4 camber, and toe in 1/32". Set the camber, went for a drive and rechecked. Adjusted as necessary. Make sure you drive the car to settle it to normal ride height before checking. Raised the front tires off the ground and rotated them against a nail in a board to determine a true line on the tire. Then adjusted the toe in and drove. Every change to the camber has a large effect on the toe. Drove, checked and adjusted several times. Then set caster, drove and rechecked camber, caster, and toe. In all this took most off an afternoon but with outstanding results and if you do not count your time, is free. Did this with a feeler guage, framing square, precision level, and tape measure.
Feel free to ask additional questions if this is not enough info.
Dan
fess40
292
Paris, Illinois
Jan 12, 2004
#10
  • Jan 12, 2004
  • #10
I may give this a try. So where can I find sthe shims?
Foxbody adjust alignment
  • Creomod
  • Jun 7, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 14, 2025
2000xp8
D
Running both lean and rich with O2 heat codes
  • Danceswithfire5
  • Aug 30, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 5, 2026
apple99Mustangdude
A
Fox Alignment Suggestions
  • PonyGTrider
  • Jul 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 13, 2025
PonyGTrider
Front Coil Overs and Rear Traditional Springs within a Maximum Motorsports K-Member Kit
  • Habu135
  • Sep 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 9, 2026
Habu135
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
