I need some ideas on where to connect the illumination wire for my new lunar gauges im putting in tonight , so need answers or ideas quick ????
01PonyGT said:I used a fuse tap at the fuse box on my 2001 GT. I forget what number fuse it was (#37 rings a bell), but it's listed in the owner's manual as "adjustable illumination". Now the guages in the A-pillar dim with the dash lights.
WES
same way I did mine...works great01PonyGT said:I used a fuse tap at the fuse box on my 2001 GT. I forget what number fuse it was (#37 rings a bell), but it's listed in the owner's manual as "adjustable illumination". Now the guages in the A-pillar dim with the dash lights.
WES
scheister said:same way I did mine...works great![]()
2002BLGT said:yea 37 was right , where did you get a fuse tap for a mini fuse ??? havent seen any
2002BLGT said:what and where did you tie in your boost gauge vacuum line ?? any pics ??
01PonyGT said:I got it at PepBoys. The one I got was made by Littelfuse, I think. It replaces the fuse and actually adds another circuit to the fuse box. You remove the fuse and replace it with the tap. the tap has two spaces for fuses. One for the original circuit and one for the new one. There's also a wire preattached that you connect to the lead from the guages. I used two of these for the guages (one for the illumination and one for the power). Works well and doesn't overload anything. I think they were about $9 each. The only down side is you can't put the cover back on the fuse box.
WES
I did the same thing......bout a month later, I couldn't figure out why my wipers would work....I just jiggled the fuse tap and they worked again. Just make sure that you have the fuse tap secure, or the vibration from the car might jiggle it loose.
