hope someone can help
  • Thread starter Thread starter rocknrod
  • Start date Start date Sep 8, 2007
R
rocknrod
va
Sep 8, 2007
  • Sep 8, 2007
In my 89 vert 5.0 aod the gears are shifting way to fast, just driving like grandma I can be in od at 25 mph, getting on it about 40 in od, my question is can I make an adjustment at the throttlebody without damage and how?
RYC CUKR
1,437
Orlando
Sep 8, 2007
  • Sep 8, 2007
The best thing is a shift kit. Then you can adjust when the car shifts more precisely. You can play with the TV cable but AOD is pretty sensitive to the proper TV setting pressure. If it is too low you can burn up the trans. In this case to high of a pressure is better than too low but still not the best.
The factory AOD shift settings pretty much suck. 2nd is almost non existant. gefore my shift kit it would shift into 2nd and if you weren't on the throttle it was an almost instant shift into 3rd. I put a transgo shift kit in and it works great. Some other guys have had issues with the transgo shifting into OD at WOT which is a big . There is also the Baumann recalibration kit which people seem to like as well.
R
rocknrod
va
Sep 8, 2007
  • Sep 8, 2007
thx
I do have a shift kit but it must suck it was in it when I got it, guess I'll take it to a trans shop
idles perfect then jolts and cuts out when put into Reverse or Drive.
  • shanesstangs
  • Mar 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2026
General karthief
Rear diff rebuild opinions
  • MrPerfect2
  • Oct 30, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 31, 2025
AeroCoupe
L
2000 Mustang PATS - Broken Key and Wire - HELP!
  • Laree Taylor
  • May 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
manicmechanic007
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
