hot starting
  • Thread starter Thread starter 65stangconvert
  • Start date Start date Jul 4, 2009
65stangconvert
  • Jul 4, 2009
i recently upgraded to an electronic ignition conversion for my distributor on my 289. about a week after i put it in, i started having problems starting the car when the engine is hot. if i wait 2-3 hours then try starting it it fires right up. but if it's hot and i go to start it 30-40 mins after turning it off, it won't start at all. it acts like it has a dead batt, slow to turn over and then nothing at all, but all my elctronics work:headlights, stereo, etc. this really has me stumped. any ideas?
wicked93gs
1,198
229
93
Nashville TN
Jul 4, 2009
  • Jul 4, 2009
first things first, check your engine grounds, the problem may be unrelated to the ignition you installed, also check the ever-failing solenoid
2+2GT
3,333
10
79
Southeastern Pennsylvania
Jul 4, 2009
  • Jul 4, 2009
Heat soak of the starter is the most likely. Do you have headers?
65stangconvert
  • Jul 4, 2009
don't have headers on the car yet. but i do believe it is the original starter and solenoid
68RCodeConv
345
Houston, TX
Jul 10, 2009
  • Jul 10, 2009
Lots of "remanufactured" starters are junk. Get a mini starter from DB electrical (about $50). It will take care of your problem.
rbohm
6,698
550
204
tucson,az
Jul 10, 2009
  • Jul 10, 2009
sounds to me like you have a bit too much timing. might be fine for a cold engine, and warmed up and you have starting issues. back the timing off a couple of degrees and see what happens.
N
nugget68
362
  • Jul 13, 2009
would this make the car sputter when it gets hot too? My car quit when I was driving it in 90* weather and then I got the "hot starter" thing where I had to put a jumper box on it, but then after it started it sputter a bit like it was almost out of gas. A few hours later it ran fine...
rbohm
6,698
550
204
tucson,az
Jul 13, 2009
  • Jul 13, 2009
this is a separate issue, likely fuel related. check the float level for proper adjustment. also do you smell fuel when this condition occurs? if so then you might also have a fuel boil issue. what happens is the carb heat soaks, and the fuel boils, flooding the engine but emptying the float bowls causing a hard start problem, and that running out of fuel feeling. a carb heat shield usually stops the fuel boiling issue.
N
nugget68
362
  • Jul 13, 2009
i couldnt smell any fuel when it happened...
M
warmed up, hard re-starting on hot days
  • michaelleewebb
  • Mar 26, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Mar 29, 2026
michaelleewebb
M
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
