I figure since doing a PI headswap bumps up the compression ratio, you can't get blown then, so how does a relatively stock non-PI 2v run? Whats tehb est setup? Anyone have any dyno graphs? Throw out all the info, results, everything.
def1eppard said:I figure since doing a PI headswap bumps up the compression ratio, you can't get blown then, so how does a relatively stock non-PI 2v run? Whats tehb est setup? Anyone have any dyno graphs? Throw out all the info, results, everything.
def1eppard said:......so how does a relatively stock non-PI 2v run?
tjm73 said:Shi*ty! You can't get much more stock than my 98. Aside from the MagnaFlow cat-back, it is 100% stock. Even has a Ford air filter.
I took it to the track and it ran a very cruddy 15.7 at 93 mph. The 60 foot time was an average (for stock Fox Mustang's) 2.12. I tried a second time and it was almost identical. I think with a little "abuse" I could have squeezed a 15.5 out of it, but it's my daily driver and I couldn't afford to hurt it.
Black Stang 97 said:What do you guys mean by PI??
