HOW DO I CHANGE A SERVO ON A C4 TRANNY
  • Thread starter Thread starter tomypasta
  • Start date Start date Jan 23, 2009
tomypasta
25
Florida
Jan 23, 2009
  • Jan 23, 2009
Can anyone please explain how I would change out a servo on my C4 tranny. The tranny is out of the car right now. Thanks Tommy
N
Nosboss
115
  • Jan 23, 2009
Are you talking about the second gear servo?
mtaqua
345
  • Jan 23, 2009
should be 4 bolts. You might have to pry a little or use a small hammer to get the cap off. Be careful, the servo piston is under pressure from a spring. Take note of how the piston is oriented (There will be a hole for fluid flow). Also, be prepared for some fluid to come out. I did it in the car and it was a PITA, but out of the car shouldn't take more than 10 minutes.
tomypasta
25
Florida
Jan 23, 2009
  • Jan 23, 2009
Nosbos I am talking about the 2nd gear servo.
After I take out the bolts and pry off the case do I have to worry about anything inside the tranny falling off or comming apart?
tomypasta
25
Florida
Jan 23, 2009
  • Jan 23, 2009
The servo I am talking about is on the passenger side of the tranny
N
Nosboss
115
  • Jan 24, 2009
Yes, you do. I replaced mine when I had a c4 years ago. You will have to drop the pan and remove the valve body. Its really very easy so don't be worried about removing those. Once you get those off then remove the servo cover and then the servo. You will see a "thing" fall out of the inside of the tranny. It goes between the servo shaft and the band. You need to put it back in place when you re-install the servo. Then its as simple as installing the valve body, oil pan and servo cover... nothing to it.
BTW, why is it being replaced?
tomypasta
25
Florida
Jan 24, 2009
  • Jan 24, 2009
the c4 I am going to ut in the car has a small Z servo and most of the Mustangs I have seen have a larger A servo.
woodsnake
1,352
15
69
Hicksville, NY
Jan 24, 2009
  • Jan 24, 2009
I tried to google this last night, and from my research, it seems like it's not really worth the effort.
Are you building high performance engine and trans, or do you just want to improve your stock trans shift?
tomypasta
25
Florida
Jan 24, 2009
  • Jan 24, 2009
Woodsnake I am trying to improve stock trans shift
N
Nosboss
115
#10
  • Jan 24, 2009
  • #10
I have never messed with a small servo c4. I will do some looking...
woodsnake
1,352
15
69
Hicksville, NY
Jan 24, 2009
#11
  • Jan 24, 2009
  • #11
You might give this a read. I don't think you will net much gain just from changing the servo, especially on an otherwise original/stock/not recently rebuilt trans.
C4 Performance Modifications - Click Click Racing Forums
tomypasta
25
Florida
Feb 10, 2009
#12
  • Feb 10, 2009
  • #12
nosboss when i change out the servo and i get the peice that falls out between the servo and the band does it stay with the servo as a matched pair or doesnt it matter when i put another servo in its place? Thanks allot
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
C
Help with manual conversion
  • CPH89LX
  • Aug 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 27, 2026
2000xp8
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Yesterday at 6:54 PM
limp
Exhaust Exhaust resonance
  • keel
  • Jul 24, 2026
Fox 5.0 Mustang Tech Aug 11, 2026
keel
C4 Transmission Servo cover leak
  • Justin87
  • May 5, 2024
2K
1965 - 1973 Classic Mustangs -General/Talk- Sep 12, 2025
Kazuja
K
