  • 1994 - 1995 Specific Tech
how do I completely drain my T5?
  • Thread starter Thread starter yellowstang1994
  • Start date Start date Apr 9, 2005
yellowstang1994
338
  • Apr 9, 2005
I'm not pulling the tranny this time and I need to completely drain my T5 with a different fluid change. If I use the drain plug I know a little sits in the bottom. Is there any kind of pump I can use to pull it out of there? What do you guys do?
HISSIN50
34
129
Apr 9, 2005
  • Apr 9, 2005
you could get a couple quarts of real cheap stuff and dump it in there once it is drained and let it come out - it would help remove the old remnants with it.
good luck.
K
kj2833
75
central illinois
Apr 9, 2005
  • Apr 9, 2005
If you absolutely have to do this, get a compressed air blower nozzle thingy. Have a pan handy, you might want to get some help, it will come flying out. Oh yea, wear some safety glasses, since you are going to make a hell of a mess.
that would be the fun way
the other way is to take a lube pump and stick the feed end in the plug hole and hope you can get it to draw some up, im not sure this will work all that well though, but a lube pump is like three dollars and they come in real handy for refilling. I use the bigger type that goes on a gallon jug, i rinse out a old antifreeze jug real good. then i pour the three quarts or whatever into there and use the pump with a rubber hose hooked to it.
Block draining
  • JD1964
  • Mar 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2026
JD1964
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
347 with Vortech V2 and Holley quick fuel, AFR Renegades a tremec tko 600 advice for newbie pls
  • Schargedfox
  • Jul 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 3, 2026
Schargedfox
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
