have 2 people. Have someone inside the car at the fuse panel, do this with all the doors closed and the car off, key out. You hang by the battery with the negative unhooked with a simple light tester. Now, check the tester by connecting the negative terminal to the negative wire. A draw would be indicated by it lit up. Pull the first fuse, then replace. When the light goes off, that is the fuse the draw is on. Good luck, and let us know if you need anymore help.
