How do I lock the hood?????
  • Thread starter Thread starter 68EFIvert
  • Start date Start date Apr 24, 2007
68EFIvert
639
Camas, Washington
Apr 24, 2007
  • Apr 24, 2007
I drive a 68 and like many of you I have a fair amount of money invested in goodies under the bonnet. I know there are locking hood pins, which I purchased recently and the body man is getting ready to install. I just don't know if I like the look though. What options are out there to secure the engine compartment?
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Apr 24, 2007
  • Apr 24, 2007
You can use a later model hood latch witch will allow you to run a cable release in the car like most modern cars use for the hood release.
CraigMBA
783
Orange, CA
Apr 24, 2007
  • Apr 24, 2007
That sounds dandy, but I don't know anyone who's done it.
Any suggestions?
2nd Mustang
2,488
Southern California
Apr 24, 2007
  • Apr 24, 2007
A big chain bolted to one side of the inner fender, through the hood and padlocked to the other inner fender sheet metal. I did this on a pick up truck. I left just enough room with the hood cracked open to fit my arms inside to unlock the padlock with a key.
My 67 coupe has barrel locks on the hood.
bnickel
5,640
lubbock, texas
Apr 25, 2007
  • Apr 25, 2007
late 70's to late 80's ford pickups had an option for a locking hood release that used the same key as the door locks, and it's safe inside the passenger compartment, also, the latch mechanism is almost identical to a 67/68 mustang, 69/70 mustangs and cougars require a little more work to the latch to make them work but they can use the truck latch as well.
stanger53
89
San Antonio, Texas
Apr 25, 2007
  • Apr 25, 2007
A simple hood locking system for 1967-1968 Mustangs:
Look at the release latch under the hood. You pull the lever up towards the hood and the catch releases, right?
Find a piece of metal tubing, like electrical conduit, that is available at places like Home Depot. Get a piece that is just a little too large in diameter to fit between the release lever and the hood. Cut off about a 2" section.
Put the conduit in a vise and clamp it down and collapse until it will just slide between the release lever and the hood. If the release lever can't be raised, then the hood can't open, right?
Install the conduit between the lever and hood. Drill a small hole through the lever and the conduit close to the edge. Buy a small padlock that will slip through the hole.
To unlock the hood, unlock and remove the padlock, slide out the conduit and raise the release lever to open the hood. It isn't the most perfect system you can install, but it is easy, quick, cheap and will keep the average person from popping your hood and messing with your engine compartment.
CraigMBA
783
Orange, CA
Apr 25, 2007
  • Apr 25, 2007
But still no solution for the '65-66 cars.
I'm putting pins in and locking the hood closed with a bicycle cable if I have to drive it somewhere.
stanger53
89
San Antonio, Texas
Apr 25, 2007
  • Apr 25, 2007
What I did on a 1965 Mustang was adapt a universal cable lock.
These locks have a locking button that mounts inside the car. The other end is a cable with a pin on it that slides in and out of the cable
You are supposed to mount the end of the cable onto the radiator support with a bracket. Another bracket mounts to the underside of the hood. When you push the locking button in, the pin on the end of the cable slides into the hood bracket, which locks the hood down to the bracket on the support.
But I didn't want any of that crap mounted on the hood or support, so I eliminated the brackets. I drilled a hole in the side of the hood latch mechanism and mounted the end of the cable in the bracket. I drilled another hole in the part of the hood latch the moves forward when you pull on the lever. Now, when the locking button is pushed, and the pin on the end of the cable moves out, the pin goes through the hole on the release lever and keeps it from moving. If the release lever can't move forward, it won't release the hood.
With this adaptation, there are no obvious brackets to mount. In fact, other than the cable running from the headlamp cavity to the latch, you can't see the lock setup at all. With a black cable, it is hard to see it even when you look for it.
CraigMBA
783
Orange, CA
Apr 25, 2007
  • Apr 25, 2007
You ran it in the fenderwell?
stanger53
89
San Antonio, Texas
Apr 25, 2007
#10
  • Apr 25, 2007
  • #10
I wanted to keep all the turns in the cable as large as I could so it would work smoothly. I mounted the part inside the car under the dash to the left of the steering wheel. I ran the cable through a hole in the firewall into the fenderwell and ran the cable through the back of the headlamp recess in the fender and into the grille area.
The cable was run high in the fenderwell next to the upper apron lip and secured in several places to the car. Because of the tire, you couldn't see it unless you really looked for it and knew it was there. It was a sealed cable, so I didn't expect any problems.
CraigMBA
783
Orange, CA
Apr 25, 2007
#11
  • Apr 25, 2007
  • #11
That sounds like as good an idea as I've ever heard.
You don't remember where you got it do you?
stanger53
89
San Antonio, Texas
Apr 26, 2007
#12
  • Apr 26, 2007
  • #12
Something I picked up from a friend who had several he had picked up where he worked. This was many years ago and I don't remember the name on the box.
I have seen these before, mounted the traditional way, on cars at shows, so I figure somebody still makes something similar.
black_demon
474
Daly City
Apr 26, 2007
#13
  • Apr 26, 2007
  • #13
there's this thing
http://www.jcwhitney.com/autoparts/Product/tf-Browse/s-10101/Pr-p_Product.CATENTRY_ID:2001344/p-2001344/N-111+10201+600000496/c-10101/reviewflag-1#review
but i havent figured out how it works or where it mounts
stanger53
89
San Antonio, Texas
Apr 26, 2007
#14
  • Apr 26, 2007
  • #14
That is pretty much what I used, only it came with a cutout wire for the ignition coil instead of a starter cutout.
I didn't use the brackets. I mounted the end onto the hood latch and fixed it so when the pin came out of the cable it slid in a hole that prevented the latch from moving.
Sbrownxx
#15
  • Jan 14, 2013
  • #15
I have the 69 key lock pins and one has jammed. Key is old and ineffective, although it works fine on the good side. Any tips on how to open the jam?
rusty428cj
943
267
104
Port Richey Fl
Jan 14, 2013
#16
  • Jan 14, 2013
  • #16
We did it on the 1967 Dynacorn build and the how to story will be featured in an upcoming issue of Modified Mustangs & Fords magazine.
iskwezm
4,159
20
79
Rowland Heights,California
Jan 14, 2013
#17
  • Jan 14, 2013
  • #17
heres a link from a while back
http://www.fordmuscleforums.com/body-paint-articles/490357-junkyard-upgrade-locking-hood-latch.html
Rusty67
20+ Year Stangneter
Dec 3, 2002
3,749
37
109
LA, CA
Jan 15, 2013
#18
  • Jan 15, 2013
  • #18
Did it jam open or shut ?
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
what would you do? sell the project and buy completed or finish project?
  • STANG32
  • Feb 8, 2025
1965 - 1973 Classic Mustangs -General/Talk- Feb 16, 2025
rusty428cj
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
