How do you test the injectors???
  • Thread starter Thread starter 1FatPony
  • Start date Start date Oct 21, 2006
1FatPony
241
  • Oct 21, 2006
I am missing in at least one chamber with my brand new engine. The only thing I didnt replace were the injectors. Is there a way to test which one if any are bad??
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 21, 2006
  • Oct 21, 2006
Have you tried pulling codes, or doing a cylinder balance test yet? Take a look at your plug wires to make sure they're all seated on the plugs and on the distributor cap completely, too. Does your new engine consist of any mods, or is it a stock replacement? When I first tried starting my new engine a few weeks ago, I had inadvertently set my rockers too tight and had next to no compression because I used the wrong method to find zero lash.
Black1987Stang
1,422
Jersey Shore
Oct 21, 2006
  • Oct 21, 2006
if u reused the injectors from another motor and they were fine im sure its a electrical problem like ill tell for ex. below......u can ohm them...use an ohmeter and check the two electrical contacts sticking out...if the circuits open then u no its def. bad...Jrichker also has a way to test in a water soapy solution and a battery and compressed air......basically u give one pin 12 volts, put little bit of compressed air into where the fuel goes into, put the bottom of the injector in a little soapy/water solution, then run a wire from the other pin and just run it to the ground of the battery and it will ground out the solenoid and pull up the pintle and turn on like it should and should make a few little bubbles from the soap from what ive heard, never seen it tho...........before u go buying new injectors tho, they are all plugged in right? I once put my motor together and got one of the wires to the #8 injector crimped under the block and lower intake when i tightened it down, it was enough to cut the wire so there was no current going to the injector...the connector was plugged into the injector also, took me about a week to figure out what it was...found out by checking for 12 volts at the injector pins at the computer, #8 didnt have power so i knew what to look for and found the wire was flat...but if ur running with only 7 injectors ur gonna know, it feels like ur running on 2 cylinders and have no power at all...Firing order correct also?
HISSIN50
34
129
Oct 21, 2006
  • Oct 21, 2006
Very good ideas here. Since you have the motor running, I'd start with the bolded part if it's easiest for ya.
Good luck.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 21, 2006
  • Oct 21, 2006
As suggested...
Cylinder balance test:
Warm the car's engine up to normal operating temperature. Use a jumper wire or paper clip to put the computer into test mode. Start the engine and let it go through the normal diagnostic tests, then quickly press the throttle to the floor. The engine RPM should exceed 2500 RPM's for a brief second. The engine RPM's will increase to about 1450-1600 RPM and hold steady. The engine will shut off power to each injector, one at a time. When it has sequenced through all 8 injectors, it will flash 9 for everything OK, or the number of the failing cylinder such as 2 for cylinder #2. Quickly pressing the throttle again up to 2500 RPM’s will cause the test to re-run with smaller qualifying figures. Do it a third time, and if the same cylinder shows up, the cylinder is weak and isn’t putting out power like it should. See the Chilton’s Shop manual for the complete test procedure
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.dalidesign.com/hbook/eectest.html for more descriptive help
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $33.
Do a compression test on all the cylinders.
Take special note of any cylinder that shows up as weak in the cylinder balance test. Low compression on one of these cylinders rules out the injectors as being the most likely cause of the problem. Look at cylinders that fail the cylinder balance test but have good compression. These cylinders either have a bad injector, bad spark plug or spark plug wire. Move the wire and then the spark plug to another cylinder and run the cylinder balance test again. If it follows the moved wire or spark plug, you have found the problem. If the same cylinder fails the test again, the injector is bad. If different cylinders fail the cylinder balance test, you have ignition problems or wiring problems in the 10 pin black & white electrical connectors located by the EGR.
How to do a compression test:
Only use a compression tester with a screw in adapter for the spark plug hole. The other type leaks too much to get an accurate reading. Your local auto parts store may have a compression tester to rent. If you do mechanic work on your own car on a regular basis, it would be a good tool to add to your collection.
With the engine warmed up, remove all spark plugs and prop the throttle wide open, crank the engine until it the gage reading stops increasing. On a cold engine, it will be hard to tell what's good & what's not. Some of the recent posts have numbers ranging from 140-170 psi. If the compression is low, squirt some oil in the cylinder and do it again – if it comes up, the rings are worn. There should be no more than 10% difference between cylinders. Use a blow down leak test (puts compressed air inside cylinders) on cylinders that have more than 10% difference.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Oct 21, 2006
  • Oct 21, 2006
Good suggestons above. Here is another more manual approach. Start by letting the engine run, when it starts missing, pull eash plug wire (insulated tool) There should be a change when you pull the plug wire. If there is not a additional miss/change in RPM, that cylinder is missing. Be sure to see if you are getting a nice blue/white arc when the wire is heald close. (A yellow ark is a weak one) then with the engine missing, shut it down. Pull those plugs. If they are dry, then that would confirm lack of fuel. If they are wet, then you are either not getting spark, or you have compression problems.
1FatPony
241
  • Oct 21, 2006
do I have to fix all my codes before I can do a cylinder test?
and my engine was running so ****ty before I put the new engine in I couldnt even tell how the injectors were working. I basically had a chunk missing in one of my heads.
Black1987Stang
1,422
Jersey Shore
Oct 21, 2006
  • Oct 21, 2006
no u dont have to fix all ur codes first....I got a couple codes and i can still fun a cylinder test on mine.
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
4.6 spitting o-rings out of 2 injectors
  • skidad
  • Sep 30, 2026
  • 2 3 4
2K
1996 - 2004 SN95 Mustang -General/Talk- Nov 4, 2026
skidad
A
SN95 Multifunction Madness! Need some big brain assistance from you folks
  • Awnaw
  • Oct 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 10, 2026
AeroCoupe
