Engine How does oil make its way into the front sump?
  • Thread starter Thread starter Sock_Monke
  • Start date Start date May 10, 2025
Sock_Monke
Fl
May 10, 2025
  • May 10, 2025
Like the title states, what carries oil to the front sump and where is it carried through?
After fixing my drain plug on the rear sump, I actually overfilled my oil by about a quart (left the oil filter on). To fix this I just popped the front drain plug off for a couple seconds.
This got me thinking, how long after I start the engine will it take for oil to flow back into the front sump of the oil pan?
Hopefully I’ll learn something here. Thanks!
General karthief
Mod Dude
Aug 25, 2016
28,116
10,733
213
polk county florida
May 10, 2025
  • May 10, 2025
The oil pan is open inside, when filling with oil the rear portion overflows into the front, no magic there, when changing the oil you take both drain plugs out to empty the pan.
Test on friday.....
Sock_Monke
Fl
May 10, 2025
  • May 10, 2025
Test on friday.....
Gotcha. So it’s purely a “spill over” pocket? Makes me wonder if I should’ve drained the oil from the rear sump, since I can’t see how any will get back into the front sump pocket now…
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
May 10, 2025
  • May 10, 2025
Both pockets fill as oil pumps through the engine and falls back into the crank case from the top.
General karthief
Mod Dude
Aug 25, 2016
28,116
10,733
213
polk county florida
May 11, 2025
  • May 11, 2025
Don't over think it, it induces pain.
As you see the 'hump' is to clear the k member and steering rack.
limp
wrap a little cheese around it and its a done
5 Year Member
Oct 4, 2020
5,518
2,941
173
Florida
May 11, 2025
  • May 11, 2025
Years ago, at a parts show, someone had built a V8 engine with clear plastic panels in areas,, It was spun using an electric motor, It showed how much oil was pumped and splashed throughout while it was running..... Its an amazing amount of oil flying around inside an engine... Surprised me .......
Reactions: Noobz347 and General karthief
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
May 11, 2025
  • May 11, 2025
limp said:
Years ago, at a parts show, someone had built a V8 engine with clear plastic panels in areas,, It was spun using an electric motor, It showed how much oil was pumped and splashed throughout while it was running..... Its an amazing amount of oil flying around inside and engine... Surprised me .......
You got a cam and crank and oil pump just splashing it all around like kids in a rain fall.
Add a little water and...
View: https://www.youtube.com/watch?v=pGL2rytTraA
J
Jarhead67
5 Year Member
Nov 24, 2018
172
64
38
Windsor Locks, Connecticut
May 11, 2025
  • May 11, 2025
I would’ve just changed the oil filter.
C
Chuckster101
32
St. Aug. Fl. 32084
May 17, 2025
  • May 17, 2025
As far as I know the front sump is filled with oil from the the timing chain and most forward camshaft. And the pickup is in the rear sump . So it shouldn’t make much difference at all ? Under hard acceleration it would splash over to the rear sump where the oil pickup is located . At least in the performance oil pan . Mine doesn’t have a front drain . Please correct me if I’m in error ?
General karthief
Mod Dude
Aug 25, 2016
28,116
10,733
213
polk county florida
May 18, 2025
#10
  • May 18, 2025
  • #10
No front drain plug? You got an aftermarket oil pan?
@Sock_Monke don't over think a stock oil pan on a street car, just open both drain plugs when oil change time comes around.
Reactions: Chuckster101 and limp
C
Chuckster101
32
St. Aug. Fl. 32084
May 19, 2025
#11
  • May 19, 2025
  • #11
Yep it’s the racing pan with the 1gt larger rear sump and smaller front sump . Also requires a deeper pickup . What’s the point of having a sump that doesn’t readily transfer? The truck pan also is similar. To the racing one .
Mustang5L5
Mod Dude
Feb 18, 2001
43,355
18,099
224
Massachusetts
May 19, 2025
#12
  • May 19, 2025
  • #12
Don't overthink it.
When the engine runs, a good portion of it is up int he engine moving around. The pickup is in the rear sump. The oil drains down front to rear and if it falls into the front sump it will eventually overfill it and it will spill over the hump and flow down to to the rear sump.
Also, it's a Mustang. Chances are your car goosing the throttle a bit here and there so that helps relocate oil from the front sump to the rear. You can see it has a nice smooth transition to help the oil go up and over.
When you do an oil change, open both drains otherwise you won't fully drain oil from the front sump.
C
Chuckster101
32
St. Aug. Fl. 32084
May 20, 2025
#13
  • May 20, 2025
  • #13
Mustang5L5 said:
Don't overthink it.
My only minor point is that its a 5 qt system and thats a qt not availible to the oil pickup for no good reason . Espçially on road courses , ford makes a factory performance pan to correct this oversight . For most it probably make a hoot . My pan was damaged and so a replaced it with the better one …?
Admin Dude
Jan 4, 1985
43,535
21,704
234
Box behind Walmart
May 20, 2025
#14
  • May 20, 2025
  • #14
So, your contention is that oil molecules being splashed around by a crank, cam, oil pump, and pushrods, all moving at 3000+ RPM, turning left, right, accelerating, and stopping, all stare at each other ruefully but stay in their own pools.
Ok
That's one scenario
C
Chuckster101
32
St. Aug. Fl. 32084
May 20, 2025
#15
  • May 20, 2025
  • #15
Ok
That's one scenario oh , heck yes sir ! Oil is much smarter then some people .
General karthief
Mod Dude
Aug 25, 2016
28,116
10,733
213
polk county florida
May 20, 2025
#16
  • May 20, 2025
  • #16
You're really over thinking this.
But a great comeback
C
Chuckster101
32
St. Aug. Fl. 32084
May 22, 2025
#17
  • May 22, 2025
  • #17
Changing the subject .how much compression do i gain by taking 030 off my stock sn 95 heads wile im reringing and bearings ?
A
Resolved 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Sunday at 3:55 AM
manicmechanic007
Who the hell puts the wrong spark plugs in a 3.8L?
  • snowstang
  • Mar 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 3, 2026
LILCBRA
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
L
Engine Normal Leakdown Results (unstarted in nearly 2 years)
  • Lube
  • May 26, 2024
Fox 5.0 Mustang Tech Jun 1, 2024
Blackhawkxx
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
