  • SN95 4.6L Mustang Tech
How does the rev limiter work?
  • Thread starter Thread starter 01mgvert
  • Start date Start date Sep 9, 2004
01mgvert
302
  • Sep 9, 2004
I have an automatic. When I run in first gear and go over 5000 rpms (approximately), the car cuts out. Is this the rev limiter or do I have other problems?
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Sep 9, 2004
  • Sep 9, 2004
stock rev limiter should be 6250 rpms I think and diablo you have should be able to adjust it .... if its just first gear there is another problem ....IMO
Premium Speed
1,006
Houston, Texas
Sep 9, 2004
  • Sep 9, 2004
my limiter is 6050...
01mgvert
302
  • Sep 9, 2004
It happens in every gear when I shift manually. I read elsewhere that the fuel pump actually shuts down when the engine is revved beyond the set limit. I am not sure what the factory setting is, but I will use my Predator to raise it a little.
Back2Mustangs
466
  • Sep 9, 2004
Not sure how Ford's limiter works, but I'm guessing....
GM's OBDII and III cut out the spark to every other cyl. when rpm's reached the limit. I'm not an ASE Certified tech, but thats the way I understood the rev-limiter to work. I would assume that Ford's and other manufacturers would be similar. Maybe you're motor is revving faster than the factory tach can keep up with and register on the dash by the time its on the limiter?
Premium Speed
1,006
Houston, Texas
Sep 9, 2004
  • Sep 9, 2004
my factory tach is around 200rpms slow at WOT
Back2Mustangs
466
  • Sep 9, 2004
I think most factory tachs can't accurately keep up at WOT, but I didn't want anyone to come back at me and be like "What? You're a moron! The tach is always right."
holler
332
Chicago
Sep 9, 2004
  • Sep 9, 2004
turn the diagnostics mode on, you'll see a digital tach readout on the odometer and then you can verify if the tach needle is off...
Premium Speed
1,006
Houston, Texas
Sep 9, 2004
  • Sep 9, 2004
that's how i did it...i accually had a friend sit in the back and videotape my dash while i made a few hits...MPH was fast a little
F
Non rev limiting cpu for 86 stang
  • Foxy86
  • Jan 19, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Jan 21, 2026
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
O
injectors keeping up?
  • optionizerSS
  • Apr 4, 2025
2005 - 2014 S-197 Mustang -General/Talk- Apr 4, 2025
optionizerSS
O
Foxbody high rpms and surging rpms
  • 86foxseth
  • Jun 9, 2026
Fox 5.0 Mustang Tech Jun 13, 2026
