How is the steering supposed to feel on a 5.0?
ramjetlx
212
Honolulu, Hawaii
Ever since Ive bought a new 06, I forgot how the steering is supposed to feel in a 5.0. Mine is really really light, I can steer it with one finger. Great for low speed driving, but not at higher speeds. I did replace the entire steering system,( rack, bumpsteer kit, hoses, pump, steering shaft,etc.)but I was having problems with the new pump whining and leaking, so I replaced it. Can anyone tell me how its supposed to feel?
if you mean that there is no resistance like in newer stangs, then that's the same way mine is. i hear you though, going on an interchange at high speed sometimes it feels like you might lose control
im wondering about this too, so hopefully someone will chime in
Numbles said:
If you want alittle more road feel and effort with your steering then you need to switch to an sn95 rack.
Can you elaborate on that? Anyone with experience swapping to an SN95 rack want to chime in here... how big of a difference, better feel for autox type driving?
I agree. My 88 GT vert has a Cadillac-like feel (a 1* turning of the wheel makes it want to turn a lot, and if I dont hold the wheel while I sneeze, the nasal flow is enough to turn the wheel. :D ).
The feel of the steering in my 94 GT is TONS better. It has that sports car feel, where it requires some input to turn and is gradual (I think that I dont like the sport ratio on the fox GT, since it is so progressive).
I have no clue if that 5N95 rack retrofit is feasible but it sounds cool.
At the same time, swap the starters (the 94's starter sounds like a normal starter). :D
I also agree that the steering is Fox cars is very light. However, i have a 4-banger rack in my car, so it's even lighter than a 5.0 rack. I can basically drive and steer with my knee if i wanted.
My '03's steering is far tighter and i love it. I just hate how the SN95 wheel is angled towards the door :(
My car is kind of loose, but not quite that loose. The few times I've had it up at triple digit speed I wasn't concerned with how the steering felt, but more of if theres a cop clocking my @$$ right now. I can turn with 2 fingers but not super easy like with my friends el camino.
I got rid of the rag joint on my car and installed a flaming river replacement to eliminate the rag joint. I can feel the road a lot better and handling has increased 10 fold. Might also be because the rag joint needed to be replaced. Who knows.
I have not paid attention a whole lot, but I know something is off with the driver's position in the seat vs the steering wheel (Mike's thoughts sound right to me). But............ I thought the same was true to a degree (pun intended) for foxes too.
The SN's have some kinda funky pedal placement IMHO too (I'm a big guy so maybe that's it).
I don't care much for fox mustangs' steering feel either. IMO it's very over-assisted and doesn't transmit any road feel. This seems to be the norm for most 80's/90's Fords, although the steering feel is definately better in the SN95's I've drove... I would definately be interested in any more info on that rack swap.
I was thinking about replacing my rag joint in the next few days... is it worth the effort? A new one is only like $12 so I figure it'll be worth a shot...
:shrug:,turning the steering wheel on my 89`,5.0L takes a little effort compared to the steering on my old 72`Mach 1.On the Mach 1,you could steer the car and turn the steering wheel with your baby finger quite easily.(even while stopped,with engine running).
My 89`,5.0L steering is not overly assisted imo.
the problem I was having with my steering was I could turn the steering wheel 1/2" while driving before the steering would react. My rag joint was totally crapped out so I opted for the flaming river replacement piece to rid myself of the crap joint.
The difference is like you stated. Better feel for an autocross driver or roadcorse driver. They bolt right up but you need new steering shaft or a wrag joint adapter.
i need new ball joints, but the steering in my stang is VERY crisp, tight, and somehwat harder to turn than any other car i've driven. But i do have a grant steering wheel which is quite a bit smaller than the stock wheel. I know that has much to do with it.
Mavrick said:
Why does it do that?
In order to clear the engine, Ford had to angle it more towards the door. It's tough to notice, but if you ever sit in an SN95 and measure the distance from each shoulder to the wheel, you'll find the pass side of the wheel is about 1-1.5" closer to you than the driver's side.
You would think they would put another u-joint up in the column, but good ole Ford decided to let it sit crooked.
Few notice it, but once you do it sticks out like a sore thumb.
