mity2 said:If i put 6, it'll go way over full on dip stick. Mine is 2001. where is this TSB at?
Kilgore Trout said:I always add 5 quarts and I change the filter always. Hmm, guess I will go check the level. All this talk about 6.25 quarts is making me paranoid![]()
tjm73 said:6 quarts per the manual.
Just an FYI, you shouldn't rely on the stock gauges for something like this. If your pressure is too low for example, the stock oil psi guage will stay in the normal zone until it's probably too late.ukgtguy said:Pressure is always just over the halfway mark on the gauge. I don't think the MAX is always a target to aim for in this case.
My best advice to you for the oil level is to rely on your owner's manual.281pony said:so for a 2k gt, it should be 5 quarts? or slightly over?
im picking my car up this week if ford ever ****ing gets going. ill probably change the oil immidiately and want to make sure. or is this something that kinda goes car to car for people?
40th GT said:My best advice to you for the oil level is to rely on your owner's manual.
streetstang03 said:was 5qts for 99-00 and 6.25 for 01-04.
