  • 1994 - 1995 Specific Tech
How much boost, stock block & internals?
  • Thread starter Thread starter spartanpride
  • Start date Start date Apr 5, 2011
spartanpride
73
  • Apr 5, 2011
This is just for fun and to learn as I have no where near close enough saved up for forced induction, yet. However say i did and ran a supercharger with the mods I have how much boost can you run with stock pistons, rods, etc? I remember hearing something about Ford using hyper-eucentric(sp?) pistons...? Anyway thanks!
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 5, 2011
  • Apr 5, 2011
The limit of the OEM block is usually based upon hp as opposed to boost
A rule of thumb is around 450 rwhp and you are in block splitting territory
Another thing about boost
Its just a measurement of back pressure
An example to be able to relate would be
Stock stang with a S-Trim might put out 12 to 14 lbs
Upgrade the major combo parts with better flowing aftermarket parts
Keep the blower pulley the same ... OR ... the blower rpm unchanged
Your boost would drop down because the restriction to airflow has gone
down due the the better flowing combo parts
Bottom line is ..............
Amount of boost is not always a factor or measurement of hp produced
Grady
GTA_V6_Mustang
1,326
Miami, FL
Apr 6, 2011
  • Apr 6, 2011
Grady.could not have put it any better. However the amount the block can take also has to do with how high you are revving it. But I would say 500 to 600 is common. Thats not tio say its going to pop right away. But your taking your chances.
Kdubslugga
1,515
Akron, OH
Apr 6, 2011
  • Apr 6, 2011
I def wouldnt go boost crazy on stock internals and block. A block isnt gonna crack at a certain hp number, but obviously the more you make the better chance you have of something going wrong. If you have a good safe tune 500-530 rwhp should be ok on a stock block but obviously is no guarantee. Avoid detonation and all will be fine.
spartanpride
73
  • Apr 6, 2011
Thanks a lot! That helps quite a bit
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 7, 2011
  • Apr 7, 2011
Just to be clear for folks that may see this info in the future
Are you talking flywheel or rearwheel HP
Grady
GTA_V6_Mustang
1,326
Miami, FL
Apr 7, 2011
  • Apr 7, 2011
Grady
hehe at the flywheel thats safe but your talking 500rwhp is asking for trouble on the stock block already. So yeah I meant at the flywheel sorry.
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 7, 2011
  • Apr 7, 2011
Good to see things which don't leave doubts
As for the range of 500 to 600 you talked about .........
Split the range at 550 fwhp and do the math
550 x .85 (driveline loss & stick trans) = 468 rwhp which is just about what
most peeps say is the point you wanna be concerned
again ... just a rule of thumb
Sure ... some have split blocks with less
and
Some have made more with no problems
Grady
GTA_V6_Mustang
1,326
Miami, FL
Apr 7, 2011
  • Apr 7, 2011
and
Grady
idk if that was meant to be a smart remark but ill take it as no. Anyway, you cant say for sure the block is going to blow at X hp. but the 500-600FWHP is a good estimate. which yea like you said is ~450rwhp. Some people have held more some people way less. This is a really good link to an article that can give some good info.
The Turbo Forums.com
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
Apr 8, 2011
#10
  • Apr 8, 2011
  • #10
No smart remark or negative stuff directed from me to you Sir
I was trying to say we were on the same page
Just saying it in a different way ... Thats All
Grady
GTA_V6_Mustang
1,326
Miami, FL
Apr 8, 2011
#11
  • Apr 8, 2011
  • #11
Grady
lol thats what I figured its just that things said over the internet lose that certain something to make it clear lol. I wish they would have made this a 4 bolt main block.... Then those newer stangs would be in trouble for sure, lol.
spartanpride
73
#12
  • Apr 9, 2011
  • #12
Thanks fellas
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Need some camshaft guru advice on power loss from supercharger to nitrous
  • TTSaleen
  • Dec 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 29, 2025
revhead347
Fox Split Block Register
  • FastDriver
  • Jun 23, 2024
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
Wheels-Tires LS mii swap and rear rim size/axle questions....
  • 78mIIman
  • Feb 2, 2025
1974 - 1978 Mustang II Talk & Tech May 6, 2025
78 Mach1
