How much freon?
  • Thread starter Thread starter 69 Rustang
  • Start date Start date Jun 4, 2006
69 Rustang
307
Orange County California
Jun 4, 2006
  • Jun 4, 2006
I recently changed the radiator support in my 73 Fastback and have the front end back together. Does anyone know how much freon the stock system holds?
66Runt
680
Jun 4, 2006
  • Jun 4, 2006
Not off the top of my head,
There should be either a tag on the compressor, or a sticker on the firewall somewhere. If you go to a shop and have it evacuated they will put it on a machine that will put in the correct amount.
You definitely need to evacuate the system for at least 45 minute or so, if you left it open. Actually if you left the system open this whole time, you should just replace the receiver/dryer. The desicant will be saturated.
Good luck,
Scott
valley82
204
San Diega, Ca.
Jun 6, 2006
  • Jun 6, 2006
The stock system was R-12 refrigerant, it will, more than likely, be replaced with either HOTSHOT (an R-12 replacement) made by ICOR, witch accually is more efficient than R-12 and is a direct drop-in replacement or converted to R-134a Refrigerant (compressor oil will need to be changed to synthetic) either way it will have to be charged by pressure not by original system weight as both replacement gases take a different charge of gas to fill the same system as R-12 does.
IMO as an HVAC/R contractor HOTSHOT is the way to go. Any auto AC guy worth his salt can charge your system to the correct charge of either of these gases by pressure.
Hope this helps...
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
G
Intro and FB questions
  • gflat65
  • Nov 16, 2025
1965 - 1973 Classic Mustangs -General/Talk- Nov 25, 2025
horse sence
Speedometer Calibration
  • Sonny Bibb
  • Sep 11, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 13, 2026
Sonny Bibb
Electrical Headlight Harness Route
  • dan50
  • May 3, 2026
Fox 5.0 Mustang Tech May 3, 2026
dan50
Drivetrain Wilwood Clutch and Brake Pedal Combo Installation - Help
  • 427stang
  • Jul 8, 2026
Fox 5.0 Mustang Tech Jul 8, 2026
427stang
