How much HP.... 302
  • Thread starter Thread starter Dugan
  • Start date Start date Sep 22, 2007
Dugan
47
Portage Mi
Sep 22, 2007
  • Sep 22, 2007
i have a 67 mustang with a 68 302 4bbl in it. the gears have been changed by a previous owner, the guy i bought it from didn't know what they were only that they are pretty low. ( like 4.56's or lower) it has headers, c4 tranny, edlebrock performer rpm intake, msd electronic ignition, automatic/manual valve bodies, and a B&M Quick Silver shifter, i was also told it had a mild cam. what would you estimate the HP and torque at?
thanks.
D
D.Hearne
11,730
south louisiana
Sep 22, 2007
  • Sep 22, 2007
Not knowing what the motor's built from (cam heads carb, compression,etc) it's impossible to say. A mild cam ( I read that to mean an RV type cam) and the intake would only add maybe 50 horses to a stock motor (heads & compression) there, you're looking at 250-275.
65fast
38
Mt. Airy
Sep 22, 2007
  • Sep 22, 2007
If you are on stock heads, I would guess 200 to the wheels
Dugan
47
Portage Mi
Sep 22, 2007
  • Sep 22, 2007
really thats it?
that doesn't make sense to me though.. i thought a compeltly stock 302 had 230 hp...
Fast63
717
  • Sep 22, 2007
I would say 200 at the wheels might be accurate. It's not a roller motor right? A stock roller 5.0 puts out about 200 at the wheels, rated at 225hp. Your intake is helping, but not 50hp worth. Hard to say how well the cam is helping too, if it is a real small cam still, probably not much. There were many 302's that were under 200hp in the 70's and the only one above 225 has been the GT-40P motors in the explorers and the GT-40 motor in the 93 cobra.
Dugan
47
Portage Mi
Sep 22, 2007
  • Sep 22, 2007
ok now i am alittle confused because you are talking about 302's from the 70s and up mine is a 68, stock rated at 230 hp and 10.1:1 compression
Fast63
717
  • Sep 22, 2007
oh, I'm sorry, I thought for some reason you had a transplanted 302 in there. But either way, I think in those days, ratings were too high. They also rated it differently, so compared to today's standards, it is probably more like 200 based on today's ratings. 230 may be accurate for flywheel horse, but you're definitely not putting that to the wheels stock. Since you have a 68 302 though, you'll be putting down more power compared to any other 302 up to 1985's roller motor.
enferno
418
  • Sep 23, 2007
isn't the 230 rated at the flywheel not at the wheels?
jeffnoel
1,638
Clovis, CA
Sep 23, 2007
  • Sep 23, 2007
Back in the day, the HP ratings were at the flywheel with no accesories on the motor.
F
fordkid
69
#10
  • Sep 23, 2007
  • #10
friend had a stock 69 302 dynoed, it made 173HP at the wheels, and 218ft tourque, it had a 4sp toploader behind it. this was in a 66 mustang with no power stearing or A/C, not much to start with but then again if they were, we wouldn't want to add our own touch to them.
Ford Kid
C
C0V3R
524
Australia
Sep 23, 2007
#11
  • Sep 23, 2007
  • #11
I was at a dyno day 2 or 3 weeks ago with heaps of mustangs.
From what I saw, if youve got a decent cam I think 200 would be spot on if everything is in excellent condition and its tuned perfectly. If its worn, tired or out of tune (rich/lean) then you will get less than 200 for sure.
D
D.Hearne
11,730
south louisiana
Sep 23, 2007
#12
  • Sep 23, 2007
  • #12
How do you know you've got a 68 302 4 bbl motor in there anyway ? Did you assemble it yourself ? Or did some one just tell you that's what it was ?
ratio411
3,870
73
109
Pensacola FL
Sep 23, 2007
#13
  • Sep 23, 2007
  • #13
Dugan said:
really thats it?
230 at the flywheel works out to roughly 184 at the wheels.
The only mods you mention that garuantee rwhp are intake and headers.
So I'll +1 on the 200 rwhp. Most of that coming from the headers.
Now if you find there has been some work done to the heads and an aftermarket cam, then you can bump it up more and more.
IF there has been no work done to the heads, an aftermarket cam will not do nearly as much for you.
Same goes for the intake and headers. They mean much more when paired with a small cam and ported heads. It's all relative.
A part is worth X amount of power by itself, but when grouped with matching parts, they are all worth their X amount, plus some.
Dugan
47
Portage Mi
Sep 23, 2007
#14
  • Sep 23, 2007
  • #14
by the serial number stamped on the block?
Dugan
47
Portage Mi
Sep 23, 2007
#15
  • Sep 23, 2007
  • #15
as i am sure you can tell i am pretty new to all of this. so i just have a couple more questions. what exacly is/is the difference between ported heads and non ported heads. also how much will the lower gears help my speed out, or are they hurting it?
Dugan
47
Portage Mi
Sep 23, 2007
#16
  • Sep 23, 2007
  • #16
what about my torque? and what is better torque or HP
i want to (eventually) make this a nice looking car that i can cruise around town in and have some fun from light to light, and occasionally take it to the strip.
where do i start on beefing it up, how much money?
thanks.
Dugan
47
Portage Mi
Sep 23, 2007
#17
  • Sep 23, 2007
  • #17
sorry for so many posts, i just thought of one last thing, i dont know if it makes any difference or not but it also has a holly 4bbl 600 cfm carb on it.
D
D.Hearne
11,730
south louisiana
Sep 23, 2007
#18
  • Sep 23, 2007
  • #18
Serial numbers or casting numbers ? If there was a serial number on the block, it would be on the flat surface behind the intake manifold. The casting number and date code are located above the starter, facing down (with the engine in the car) Head casting numbers are located on the bottom side of the intake ports (on the heads) the date code is located inside the rocker valley, up next to one wall, accumulated gunk usually covers this, so you have to dig to see it. Date codes are a number/letter/number(s) combo, the 1st number is the year of the decade it was made, decade is determined by the 1st two characters of the casting number. The letter is the month, runs alphabetically with "A" for January, thru "M" for December, they skipped the letter "I". The last number or numbers is the day of the month it was made. If you cannot remove the intake or heads, it can sometimes be hard to Id the heads, it can be narrowed down with the date code, but with Ford using several heads in the late 60's for each model year, ID'ing it without the casting numbers can be a crap shoot. The 68 4 bbl 302 also used some specific parts to acheive the rating it had. These parts were different from those used on the 2 bbl motor, then to further complicate things, Ford was phasing out the 289 motor too in 68, so it's impossible to distinguish a 2 bbl 68 289 from the 2 bbl 68 302, without looking at the crank casting number. The parts that separated the 4 bbl 302 in 68 were the heads & intake, and possibly more, these two I know for a fact were unique to this motor. The heads were basically remakes of the 66 289 (C6OE) head with new casting numbers. The intake was as well , basically a recasting of the iron 289 4 bbl intake with 68 numbers (C8ZE-9425-A)
D
D.Hearne
11,730
south louisiana
Sep 23, 2007
#19
  • Sep 23, 2007
  • #19
Nothing wrong with asking questions--------ask away. You can go back though and edit a post using the edit button if you want to reduce the number of posts.
R
rc4mike
142
#20
  • Sep 23, 2007
  • #20
I have a mid 80 302 with headers, edlebrock 650 card, power steering....getting 189 at wheels with c4 trans. The dyno guy said that's about 224 and engine
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
For Sale 1986 Capstang (Part Capri & part Mustang) $12,000 Galena, Ohio
  • BubbaG
  • Aug 7, 2022
2K
Fox Body Mustangs For Sale (1979-93) Aug 7, 2022
General karthief
New to me Fox body. Looking for Rough HP and compression ratio
  • Halford4491
  • Oct 30, 2021
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 3, 2021
General karthief
Progress Thread 1/4 mile guess?
  • 78mIIman
  • Oct 16, 2019
2K
1974 - 1978 Mustang II Talk & Tech Jan 14, 2020
Adieu
