How much power with c-heads
  • Thread starter Thread starter wiking
  • Start date Start date Oct 3, 2005
W
wiking
33
åmål, sweden
Oct 3, 2005
  • Oct 3, 2005
I have a pair of heads from a 351 C 2V somewhere in the basement. How much power can I expect to gain by using theese on a 302 winsor 2V. Is it worth the effort, and have any of you done this?
ss93cobra
1,422
Wilmington NC
Oct 3, 2005
  • Oct 3, 2005
Sorry to be the one to tell you this, but I don't think you'll be able to get them to fit.....
Boss 351
Here sthhhhhhhheeeve take a picthh of my man flowe
Jul 13, 2003
2,433
23
48
Canada
Oct 3, 2005
  • Oct 3, 2005
You'll need a special and hard to find intake manifold for those heads to fit on a windsor.
vristang
4,933
101
124
Seattle
Oct 3, 2005
  • Oct 3, 2005
They will fit. But there are some issues. The Ford Racing catalog used to have instructions on the how to.
The probem is that these heads shift the power band too high for street driving. With the Boss 302 it was almost too high for racing. It just depends on what you are looking for. There are some variations in the runner volumes/sizes if I remember right, so the degree of rpm shift could vary a little.
That's what I remember.
jason
W
wiking
33
åmål, sweden
Oct 3, 2005
  • Oct 3, 2005
As I recall, the Boss 302 used 4v and not 2v heads, right?
vristang
4,933
101
124
Seattle
Oct 3, 2005
  • Oct 3, 2005
Not sure, but that sounds correct.
Guess I don't remember as much as I thought I did.
W
wiking
33
åmål, sweden
Oct 3, 2005
  • Oct 3, 2005
vristang> have you got a guess on the powergain?
nosmatt
1,356
Bass Lake, Ca
Oct 3, 2005
  • Oct 3, 2005
when it is all said and done, a set of afr or twisted wedge heads would be cheaper (even if the clevland heads were free!) and will make more torque, and hp.
it's an older trick, aftermarket windsor heads did not exist way back when, and the stock crap was, well........crap. 2v clevland heads flow a good bit better than gt40 irons, in some places.........and in other lift ranges, alot worse.
Modular2v
3,222
23
99
oklahoma
Oct 3, 2005
  • Oct 3, 2005
there is a water jacket alignment problem but you can get it to work....i have a pair of 4v heads if you want them off a cleveland
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Oct 3, 2005
#10
  • Oct 3, 2005
  • #10
See http://www.pricemotorsport.com/index.html for manifolds & manifold adapter plates.
W
wiking
33
åmål, sweden
Oct 3, 2005
#11
  • Oct 3, 2005
  • #11
I would just loooove to get my hands on a set of 4v heads, but I`m afraid that the freightcosts from Oklahoma to sweden will be higher than the price of a brand new set of performance alu-heads But thanks for the offer!!
The thing is that I`m already in possesion of a set of 2V heads, I`m just wondering if I would gain an amount of power, that make it worth the effort to try to make it work.
RMODEL65
313
brunswick ga
Oct 3, 2005
#12
  • Oct 3, 2005
  • #12
yes a big gain they flow well with or with out a port job i believe edelbrock has a new intake for the cleavor swap since they have introduced the new alm cleveland head the 2v heads are open chamber so to keep ur compression up u might need pop up with good ports for great low end. The 4v used quench chambers and giant ports = no low end torque but tremendous high end but the best cleveland head is the aussie version it has the 2v ports and the quench chambers for an almost unbeatable combo for the low dollar amount also i think bush racing had an intake for this conversion. my auto mechanics teacher had a four wheel drive ranger with 347 stroker with clevand head and a x303 cam it was extremely fast and it had an open rear end w/3.00 gears i know it was faster than a wrx sti since i have driven both
Engine (EGR Deleted) Solution the hotter combustion chambers?
  • PonyGTrider
  • Jan 21, 2026
  • 3 4 5
5K
Fox 5.0 Mustang Tech May 2, 2026
PonyGTrider
G
Electrical Getting good ground in 1991 Fox Vert for amps - getting popping noise when I turn on the lights?
  • gvanginkel403
  • Apr 11, 2026
Fox 5.0 Mustang Tech Jul 21, 2026
gvanginkel403
G
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
  • Mindseye007
  • Aug 16, 2026
Mindseye007
