R romgolferman Founding Member Mar 24, 2001 355 0 0 St. Louis Jun 15, 2008 #1 Jun 15, 2008 #1 ok after i get the oil pan off how do i change the rod bearings. what other damage do i need to look for.
flstang65 10 Year Member Dec 6, 2007 1,484 135 94 SE Georgia Jun 15, 2008 #2 Jun 15, 2008 #2 grab a haynes or chiltons manual. they are pretty good at explaining that type of stuff. you can pick them up for like 15 at most auto parts stores.
the98stang Active Member Aug 12, 2005 2,408 0 47 Clovis, CA Jun 16, 2008 #3 Jun 16, 2008 #3 romgolferman said: ok after i get the oil pan off how do i change the rod bearings. what other damage do i need to look for. Click to expand... Are you serious??????? .................If this question is serious you shouldn't be changing the bearings or messing with any other part of the engine because one small mess up and you'll just end up rebuilding again.
