How to fix ground effects?
  • Thread starter Thread starter 98coyote
  • Start date Start date Nov 24, 2004
9
98coyote
24
Leighton, Alabama
Nov 24, 2004
  • Nov 24, 2004
Does anyone know how to fix a tear or a gouge in a 93 gt ground effect or bumper cover ?
MahFiVeOh
531
9
49
Ontario, Canada
Nov 24, 2004
  • Nov 24, 2004
Got a pic of the damage?
C
crunchie12268
599
Manhattan, KS
Nov 24, 2004
  • Nov 24, 2004
can't you use some fiberglass like stuff and then fill it in with a plastic type of bondo? Same problem on my old GT, fixed real easy.
The Shape
2,224
East ARKANSAS Delta
Nov 24, 2004
  • Nov 24, 2004
Yep fiberglass repair kit will do it. just practice mixing it and applying it on something else first to get a feel for it if it is your first time using it.
N
Nottoofast50
386
Cali
Nov 24, 2004
  • Nov 24, 2004
so fiberglass over it then smooth it with bondo for holes/scrapes in ground effects?
DirtyD916
804
Norcal 916
Nov 24, 2004
  • Nov 24, 2004
be sure to sand down the service prior fiberglass for a smoother surface, then sand after bondo ( 2 coats should be enough depending on the size)
DirtyD916
804
Norcal 916
Nov 24, 2004
  • Nov 24, 2004
hey MahFivOh got a pic of your car?
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Nov 25, 2004
  • Nov 25, 2004
copied from MSTANG
Automotive Aftermarket
Truck Line EZ Sand Flexible Parts Repair
08276, 400 mL, 6 per case
Two-part epoxy used to repair most plastic parts, including bumper covers, and other plastic body panels (not for use on SMC/fiberglass). Use 3M™ Polyolefin Primer 05907 for system II plastics. 10 minute work time, 30 minute sand time, 4 hour cure time
Buyer's Part Number : 08276
GTIN(UPC/EAN) : 0 00 51135 08276 8
3M Id : 60-9800-3708-3
ADDITIONAL INFORMATION
Automatic mixing. Designed to be used as a filler and adhesive. Epoxy based for easy sanding. Formulated for excellent feather edge.Flexible through a wide range of temperatures.
CHARACTERISTICS
Clamp Time
1 Hour
Color
Gray
Cure or Dry Time
4 Hour
Work Time
10 Minute
3M 1995-2001
W
wild50gt
51
nj
Nov 25, 2004
  • Nov 25, 2004
i had a 3 inch tear in my front fender extension on my GT. i used this black bumper repair kit... 2 step epoxy and resin type deal, it's flexible and STRONG. i sanded it down, primed it, painted, just like new. and its not expensive either $7 tops.
MahFiVeOh
531
9
49
Ontario, Canada
Dec 12, 2004
#10
  • Dec 12, 2004
  • #10
A bit late but yeah
http://www.mustangmods.com/data/7254/mine.jpg
jaidedeye
627
Goldsboro nc
Dec 12, 2004
#11
  • Dec 12, 2004
  • #11
i have an idea ,
rip all the ground effects off your car and convert it to an lx......much better
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
Spare tire orientation?
  • Bib36`
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 25, 2026
JD1964
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
F
Ground wire
  • fox1990
  • Feb 12, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 12, 2026
manicmechanic007
