How To Install-Sequential Tail Light Kit ***pics***
94GTCoupe
1,412
92
79
CA
i installed this kit last week,just now had time to post this up.
this is basicly a reproduction of the guide that comes with the kit.
but with my own color pictures and a little (crappy) video at the end.
the kit i'm using is the splice in kit for 96-04 mustang.
its the STS-1M,can be found at the link below for about $70.(got mine on the corral for $50 :) )
Sequential Turn Signals, One Touch Turn Signals, Challenger Sequential Taillights, Sequential Tail Lights, Mustang, Dynamite Stick Sequential, Pulsing Brake Light Pulser Flasher, One Touch Convertible Top, Dynamite Stick, One Touch Turn Signals, Dayt
-----tools needed-----
1.sequential light kit(comes with everything needed for install)
1-needle nose plires
1-wire cutter/stripper
1-small pointed tool
2-dual filament bulb for #1 light socket(you may or may not need these,depending on whats in your tail lights)
for light housing
1-3/8 drive ratchet
1-3/8 drive,7/16 deep socket
PASSANGER SIDE.
TAIL LIGHT HARNESS WIRING
ORANGE/BLUE STRIPE=signal wire
BLACK=ground
MODULE WIRING
RED=signal input
BLACK=ground
BLUE=signal output
WHITE=signal output
1.back of tail light housing.
#1.inner light
#2.center light
#3.outer light
R.reverse light
2.remove #1 light connector from housing
3.with small tool,pry rubber seal out of light connector
4.with pointed tool,poke hole in rubber seal as shown.
5.insert yellow wire through hole.(supplied with kit)
6.with needle nose pliers,insert pin into light connector.make sure its fully seated.
7.replace rubber seal
8.place light connector back in tail light housing.
9.remove tape wrapping the tail light wiring,you will need some slack in the wiring for the next step.
10.swap the positions of #1 and #2 light connectors as shown.
11.with pointed tool,poke two holes in tail light wiring grommet.
12.from sequential light module,feed the BLUE and WHITE wires through the holes.
13.near tail light harness connector,remove tape wrapping the wiring as shown.
14.on tail light wiring,find the ORANGE/BLUE STRIPE wire,
15.using the supplied quick splice connector,connect the ORANGE/BLUE STRIPE wire with the RED wire from the module.
use your plires to press togeather the quick splice connector to ensure a good connection.
16.find the BLACK wire on the tail light harness and with quick splice connector,connect to the BLACK wire on the module.
17.back at the #1 light connector,with supplied wire nut,connect the YELLOW wire with the WHITE wire coming from the module.
18.at #3 light connector,cut ORANGE/BLUE STRIPE WIRE.
19.with supplied wire nut,connect the ORANGE/BLUE STRIPE wire from #3 light connector with the BLUE wire from module.
20.with supplied zip ties,tie up all wiring so its nice and neat.
passanger side is done.
21.install tail light housing.(driver side shown.)
feed connector and module through,pull grommet into place and bolt in housing.
make sure no wires are in between the housing and body.
for the driver side,same procedure
DRIVER SIDE
GREEN/ORANGE STRIPE=signal wire
BLACK=ground.
here's a quick video of sequential light kit installed.
not very good,i'll get a better video later.
i like it alot,a little fast,but i can live with it.
brake,left,right,and hazard.
http://www.youtube.com/watch?v=ZzPc87j5sa4
my only suggestion is to solder the connections instead of using the pos 3m connectors or wirenuts..
In the pictures you posted, there is still bare wire hanging out the end of the wiretaps... besides the fact they are prone to fail.
+1 on the soldering but those are self-piercing scotchlocks, actually pretty good connection for a non-signal/ECM type tap.
i cut the bare wire flush with the quick connects.
i plan on soldering and heat shrink covers when i'm not so lazy.
lol,tell me about it.
my browser froze up once :mad:,and i accidently closed the window :doh: another time when i was almost done with the write up.
took forever to get this up!
