how to put center console together??
Wil
581
Burke, VA
Ok, well I have been in the process of converting my gray/black interior to complete black. But I took a huge break in between so now I'm lost of how to put the arm rest part of the center console back together. I took it completely apart so i could paint every part evenly.
Consel itself goes in first. 2 bolts and six skrews hold it in. Then the tray goes in next.. 4 skrews hold that in.. Then the armrest goes in 4 bolts hold that in.. It bolts to the little black metal box there. Hope that helps not rocket science but close to it.....
im not 100% sure what youre asking but if its about putting your armrest together piece by piece read ahead. if not, disregard the following. For the armrest itself, start with the base of the actual armrest.put the black, metal piece in that. Then in goes the black, plastic piece (the one with cassette holders), screwing it down with 4 screws. next you put in the release button with the metal spring behind it (bending foward) and screw the cap down over it. then with the top of the armrest, slide the metal hinge in between both pieces and screw it down. Dont use too long of screws or it will strip out. It is a little bit adjustable. I had to move it all the way up. hope this helps. When you get it all in, post pictures so i can see what it looks like all black. if it looks good, maybe ill do it too.
