Pull the door handle/bezel out, then pop the snap off the front of the door panel. Its kind of hard to find but its toeards the bottom. There will be some screws behind the handle/bezel (the one you pull to close the door). You dont have to take the handle bezel off unless you want to. (not the one you pull to close the door, the one you pull to open the door).
It also sort of helps to take the lock covers off. Then just slide it up and then pull it off. Its a PITA to put back on, just line all the hooks on the bottom up then try to get the top lined up right.
I have a coupe but I m pretty sure the doors are the same on verts and coupes.
