How to Remove Instrument Cluster?
  • Thread starter Thread starter 91StangGT5.0
  • Start date Start date Mar 2, 2010
91StangGT5.0
162
Mar 2, 2010
  • Mar 2, 2010
How do I remove an instrument cluster on a 91 Mustang GT?I need to get to it first. I'm trying to change the speedo cable and it's a pain in the ass reach up behind.
skunk21
1,203
Taxachusetts
Mar 2, 2010
  • Mar 2, 2010
It's been a few years since I have had mine off so I'll try and remember for you but it's pretty easy. remove the kick panel from under the steering wheel, it has 2 small bolts on either corner at the bottom holding it on and then pulls off. next remove the collar from around the steering column, there are 2 screws from the underside holding together ( it's in 2 halves). this will gain you access to the lower screw tabs holding the gauge shroud, there are also 2 more on the top side recessed into the shroud. the shroud should lift up enough so you can unplug the headlight & hazard switches. now you have full access to the gauge pod, you'll see the mounting screws holding it in should be 4 if I remember, you will be able to pull it forward enough to reach back there to pop off the speedo...note sometimes it can be a PIA but it will come out.
This is all from memory and pretty accurate ( my car isn't at my house to run down and look at ) but if I'm off on something someone will chime in I'm sure.
Tanus
847
A to the Z
Mar 3, 2010
  • Mar 3, 2010
let me know how it goes once you do it, I have to pull mine to swap the speedo cable too and replace fuel level gauge.
tannerc91gt
This last 25% is foreign territory at this point
2,967
234
Indiana
Mar 3, 2010
  • Mar 3, 2010
I just pulled and reinstalled mine yesterday. That is the correct way to do it but can be a pain to unplug/plug the harness back in
Interior and Upholstery 1993 Instrument Cluster cover
  • KevinV
  • Jul 2, 2026
Fox 5.0 Mustang Tech Jul 3, 2026
AeroCoupe
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
Hello and Instrument Wiring
  • GT Jon
  • Jul 5, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 6, 2026
Mustang5L5
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Dash wiring
  • RileyDymond
  • Jul 19, 2026
Fox 5.0 Mustang Tech Jul 19, 2026
RileyDymond
