There are 2 releases under the seat cusion. They are about the middle of each passenger location. Take a flathead screwdriver with the blade horizontal ( like this - ) and run it under the bottom of the cusion to locate the releases. When you hit the side of the release pull the screwdriver out far enough to get in front of it (but not out from under the seat cusion), slide the screwdriver over about 1/2" to 3/4", turn the screwdriver 90 degrees ( like this ! ) and push forward. This should push in the spring clip and release the seat. There are two of these releases, one on each side. Hope this was clear enough.
