  • 1994 - 1995 Specific Tech
How to remove rear seats?
  • Thread starter Thread starter WhiteDevil
  • Start date Start date May 26, 2007
WhiteDevil
2,717
San Diego
May 26, 2007
  • May 26, 2007
Im sure its not that hard but i am going to tackle it tommorow and wanted a heads up before i go into it. Just some quick cliffs notes will do fine. Thanks stangnet.
1slow95
1,797
ohio
May 26, 2007
  • May 26, 2007
If your release buttons are messed up like mine it's a PITA! The release button is about right in the center of the seat on each side, right beneath the front of the cushion. Push that button straight back and lift up on the seat. A flat screwdriver is required, and possibly a BFH.
I don't know about the seat backs, but I'm guessing there's just a few bolts holding them in. Good luck!
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
May 26, 2007
  • May 26, 2007
The bottom one comes out with pushing in on the release about mid way between each cushion. For the back there are three bolts in the bottom that you will find once you remove the lower part of the seat. You then lower the seat backs and take out the three bolts that hold the top pad on. Once you lift this out you will see two more bolts that come out. Now the entire seat frame will comeout. All of the above mentioned bolts are 10mm. I actually took all of mine out today to clean them with my carpet cleaner and it took all of 5min to take the back seat out.
Fox Full set of seats in the back of a hatch
  • keel
  • Aug 28, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 31, 2026
keel
R
Interior and Upholstery How to remove seatbelt torx screw
  • Riley Barth
  • Jul 6, 2026
Fox 5.0 Mustang Tech Jul 13, 2026
Y
2004 Roush - Dome Lights and radio not working
  • Yurei
  • Nov 10, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 20, 2025
squeak93
T
Engine Removal of Steeda Underdrive pulley
  • THughes
  • Jun 30, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Jul 4, 2026
Dino Dino Bambino
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
