How To Test the Radiator Fan?
94-302-vert
1,947
NE CT
Hey question for you guys. I went to check t see if my high speed fan was turning on yesterday and even running with the A/C on the fan was not turing. So while i plan to actually put in a manual switch i would also like to test the fan itself. Anyone have the pinout for the fan so that I can test it (3 wires I think)?
My Haynes is at home so I don't know if this wiring diagram is in there or not.
Thanks Guys.
A quick and easy test you could do is just plug-in the OBD1 code reader, and the first thing it will do is cycle both fan speeds. If you hear the relays clicking but no fan, there's a good chance the fan itself is toast. But if you don't hear the relays clicking and also no fan, then the CCRM is the likely culprit, and wiring a manual switch could be your answer.
In addition to Stephane's wise thoughts.............
Lookin down at the fan from the hood (as opposed to being under the car), the top fan terminal is ground, middle is low, and bottom is high speed.
It's probably all stuff you know but here are a couple of quick tech notes:
One. There's a little info in the middle of that one which might apply.
Two
I will also note that the fan can pass the self test (you hear both speeds cycle) but in it's true dynamic, one or the other speed wont come on. A couple of times I've seen high speed not come on with the AC (instead low speed continues to run when high should be running).
Good luck.
