With a nice suspension setup from maybe Grigg's Racing or Maximum Motorsports, how good can it actually get? Can it compare to high end import cars such as Euro's, Japanese, Italian, etc.
My friend has an M3 and another has an IS300 and it makes me mad how I can't hang with them in the highspeed curves, and can't carve the sharp turns. If my stang could do that, it'd be awesome.
Or would I be better off waiting 'till I can afford the '05?
(just wanted to get that out first) following you in this thread I'm agreeing with you and the points you've made. I would like to throw just a little different spin though, on how it vexes you that some of us get so carried away with the torque arms in our stangs (not that we haven't been round and round on it before) -just a twist. To say that there is nothing exotic about having a torque arm in a Mustang (because they are found in SUV's, F-bods and even Volvos) is like saying there is nothing exotic about having a V10 in a Mustang because they are found in big Ford pickup trucks. I think you are throwing the baby out with the bathwater a bit. You can't compare the Triton to Fords one-off '99 V10 GT (dubbed "Boss"), and you really can't compare an SUV torque arm to one developed by MM or Griggs. It's apples and oranges. Even the F-bods have aftermarket companies making torque arms for them that are far superior design than the ones they had from the factory. Half the articles I've read on the '05 GT claim it has a torque arm. I've seen the rear layout, and it just isn't. It is simply a three link with a panhard, with only one upper control arm. It doesn't look anything like my torque arm, doesn't attatch the same, locate in the same area, and will not even remotely do the same job in even remotely the same way that my MM one does. These two designs aren't even third cousins, nevermind calling them both torque arms. Considering that most true "exotics" don't even run a solid axle at all, technically the IRS in some Thunderbirds and Cobras is by design more "exotic" than any of them- but that isn't really the point. My MM torque arm suspension is exotic because a torque arm was something that Ford never dreamed of giving us in a Fox Mustang. Just like there is nothing magical about a properly located four link, because they all came with four links, the magic isn't the torque arm itself, the magic of the torque arm is what Griggs and MM have done with it for us: the design, not the name. We are psyched because with this design we can handle far better than we could with the design Ford gave us, or any parts that will bolt into the places Ford supplied; while retaining our backseat and without having to back-half our cars. It's almost too good to be true- like magic.
