HP Calc.
  • Thread starter Thread starter 65notch
  • Start date Start date Jul 13, 2006
65notch
303
661 Cali
Jul 13, 2006
  • Jul 13, 2006
anybody know a site that has a horsepower calculator that uses 60ft, 1/4 et, gears, etc to estimate rear wheel hp? thanks
ps. i did a search but didnt find anything, only engine sims
classic boost
709
canton, oh
Jul 13, 2006
  • Jul 13, 2006
try: http://www.hardcore50.com/members/calculators.htm
65notch
303
661 Cali
Jul 13, 2006
  • Jul 13, 2006
whats the weight of a 65 coupe 289? 3000?
classic boost
709
canton, oh
Jul 13, 2006
  • Jul 13, 2006
yeah, that should be close ballpark.
65notch
303
661 Cali
Jul 13, 2006
  • Jul 13, 2006
thanks..... these numbers im comming up with are depressing. ouch i think i need heads
geostang351
946
Danb., CT
Jul 14, 2006
  • Jul 14, 2006
What are the numbers?
180 Out
375
  • Jul 14, 2006
The formula is rear wheel hp = weight x (trap speed/234)^3. Therefore, the higher the weight, the more the hp. 3000 lbs may be too high for a '65, maybe not. Flywheel hp = rear wheel hp/.80 for an automatic, hp/.83 for a stick.
M
mustangdave
My rearend needs a stud and two nuts.
2,976
North Carolina
Jul 14, 2006
  • Jul 14, 2006
Is it just me or are these calculators whacked? Is asks for h.p. and weight. A 200 h.p. car w/300 lb. ft. of torque will be faster than the same weight 200 h.p. car w/ 250 lb. ft. of torque, so how can it be accurate?
Dothang67
133
  • Jul 14, 2006
What exactly is trap speed?
180 Out
375
#10
  • Jul 14, 2006
  • #10
I think the answer is, yes, the hp-based ET calculators are whacked. They will generally tell you that the same hp that will achieve a 102-103 trap speed will also give you a 12.99 ET. The truth at the track is, only if you get a monster hook is a low 100's trap going to be good enough for 12's. The ET-based hp calculators are whacked too, for the same reason. A lot more goes into ET than hp and weight.
On the other hand, the trap speed-based hp calculators tend to be pretty close. Somewhere there's a web site that explains the physics behind the formula, rwhp = trap speed x (weight/234)^3. But even so, the formula assumes a constant rate of acceleration, which is impossible to achieve in real life. But it's not impossible to get close. That's why the formula works as a guesstimator.
Editorial comment: with the proliferation of Dynojets and similar chassis dynos, people are getting much too obsessed with their hp output. A dyno is useful for tuning, but so is trap speed at the track. IMHO it's a waste of money if all you want is to get a number to brag about.
65notch
303
661 Cali
Jul 15, 2006
#11
  • Jul 15, 2006
  • #11
the hp numbers i were getting where right around 260 fwh and 225 rwhp.
im trying to get a good idea of what she puts out just so i have something to go by as i work on improvments.
what does a stock 289HI-PO put out from the 60s?
Cobain03
996
Lexington, Ky
Jul 15, 2006
#12
  • Jul 15, 2006
  • #12
whats your mods?
67Dylan
259
Phoenix, AZ
Jul 15, 2006
#13
  • Jul 15, 2006
  • #13
I couldn't agree w/you more!! It's just a tool, a good one at that, but it doesn't tell you what's king... ET baby! When I had a custom cam by Ed Curtis I talked about HP. He stopped me and asked what was my ET goal. He said he could grind a dyno queen or an ET king... went w/the ET king.
Tune at the track. One item at a time. Let the ET tell you which way to go and when to stop.
65notch, next time you go to the track PM me. I wouldn't mind tagging along and helping you out if you needed it. Speedworld isn't that far from my house (20min)... plus would be nice to meet you & check out your ride.
68RustBucket
119
Linwood, NJ
Jul 15, 2006
#14
  • Jul 15, 2006
  • #14
Ford advertised 271hp at the flywheel, I believe
65notch
303
661 Cali
Jul 15, 2006
#15
  • Jul 15, 2006
  • #15
67dylan, will do..im watchin the weather...maybe this upcomming week..it will be humid but i can deal with that instead of 115. ill let u know
65notch
303
661 Cali
Jul 15, 2006
#16
  • Jul 15, 2006
  • #16
Cobain03 said:
whats your mods?
289 .030 over
Edel performer rpm intake
600 4bbl carb
performer cam(i think)
9.2:1 CR
stock heads w/ 1.6 roller tip rockers
Tri Y headers, 2 1/2 dual w/ H-pipe
MSD ignition,
non engine mods: electric fuel pump and fan. alum rad. t-5 trans, 3.55 LSD rear.
think thats bout it
LUCAFU1
496
Tucson
Jul 15, 2006
#17
  • Jul 15, 2006
  • #17
ETs is whats its all about, although AZ ETs will make a grown man cry
Cobain03
996
Lexington, Ky
Jul 16, 2006
#18
  • Jul 16, 2006
  • #18
65notch said:
289 .030 over
600 4bbl carb
9.2:1 CR
MSD ignition,
think thats bout it
That is REAL close to mine.
bored 30 over, performer intake (rpm coming soon), 600 holley, same spec cam, stock heads, tri ys with H.
i put down 218, 269
O
SOLD FS: 18" FR500 chrome wheels and Toyo tires
  • optionizerSS
  • May 21, 2026
  • Other Classifieds
Other Classifieds Jun 2, 2026
optionizerSS
O
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Aug 4, 2026
jake411
J
D
66 Coupe Progress Thread
  • DTCRAWLEY
  • Apr 19, 2026
  • 2 3
1965 - 1973 Classic Mustangs -General/Talk- Jun 17, 2026
DTCRAWLEY
D
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
