  • SN95 4.6L Mustang Tech
hp gain
  • Thread starter Thread starter 04gtboy
  • Start date Start date Nov 28, 2005
  • 3
1 of 3 Next Last
04gtboy
83
  • Nov 28, 2005
i just ordered a bbk x o/r pipe and flowmaster am thunder cat with mil elimaters my first mod whats factory hp and how much will i gain
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 28, 2005
  • Nov 28, 2005
1) Factory hp is 260
2) Zero hp gains from the exhaust
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 28, 2005
  • Nov 28, 2005
Maybe 7-8 from the midpipe. The catback is a toss-up. Some say 0...others claim 4-5HP. You will not "gain" flywheel HP meaning you will still be at 260 but you will free up some that is lost at the wheels.
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 28, 2005
  • Nov 28, 2005
Ok, well Coramprat knows more than I do but I still say no SOTP difference...
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Nov 28, 2005
  • Nov 28, 2005
SOTP meter definetly will feel the midpipe...i know i did. like coramprat said ~10hp from midpipe and no more than 5hp from the catback.
keep in mind the 260hp rating from the factory is fly wheel hp, not rear wheel hp.
ponysarepretty
578
  • Nov 28, 2005
coramprat said:
Maybe 7-8 from the midpipe. The catback is a toss-up. Some say 0...others claim 4-5HP. You will not "gain" flywheel HP meaning you will still be at 260 but you will free up some that is lost to the wheels.
you are gaining flywheel HP, the only time you will free up parasitic loss is when you change a component of the driveline. think about it.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 28, 2005
  • Nov 28, 2005
My e-dyno broke so i can't help
K
Kilgore Trout
Fried or Broiled ?
4,749
95
134
Nov 28, 2005
  • Nov 28, 2005
Is it too late to change my answer?
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 28, 2005
  • Nov 28, 2005
It's just numbers though...I barely felt anything from my swap (still have the stock catback) but my dyno numbers say different.
I based my findings on this: Went to a dyno day. There were two other NPI GT's besides mine. One had no mods except K&N and American Thunder catback. He dyno'd at 174HP...
Second car had mods similar to mine except the PI intake and he had full Bassani exhaust w/an X and 3.73's...197HP.
My car...PI Intake, Mac Prochamber, fenderwell CAI, TB and plenum Screamin' Demon Coils, 4.10's...213HP.
I think the difference in cars 1+2 was the X...mine made the power with a combination of the midpipe and the upper air flow. I haven't dyno'd since my cam install but thinking I'm around 235 now. Keep in mind these were NPI cars (mine being a PI intake swap only with stock heads). Your results on the PI car will probably be a little better.
COramprat
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
Nov 28, 2005
#10
  • Nov 28, 2005
  • #10
But all you are doing is increasing the output air flow with a midpipe? The engine is rated at 260 (Mine is 215 :roll: )and you are restricting that with cats in relation to your RWHP. That will decrease your RWHP. Pull them off and you increase your RWHP but the FWHP won't go up until you make increases in upper airflow. Maybe I have my info wrong...
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Nov 28, 2005
#11
  • Nov 28, 2005
  • #11
you will see increase in both WHP and FWHP since the cars are rated at 260HP at the fly the parasitic loss is roughly about 15-20%. So if you gain RWHP then the HP at the fly should go up also, since the engine is not forcing the exhaust out like when it had the Stock mid pipe, now it will flow more freely.
tomustang
Psychotic Member
3,434
McLean Hospital
Nov 28, 2005
#12
  • Nov 28, 2005
  • #12
ponysarepretty
578
#13
  • Nov 28, 2005
  • #13
I think you have your logic a little wrong. How much air goes in and out of your engine does effect how much power it makes. Because an engine is basically a massive air pump, the more air that is moves, the more power it will make, in theory. The cats restrict air flow, thus dampening your motor's ability to produce power. However something liek the tranny and the sound energy it gives off eats up power as it goes from your motor to the ground.
C
comporange04GT
110
#14
  • Nov 28, 2005
  • #14
I have to agree. I guess you can look at it like this: It is the same thing as doing an engine buildup and dynoing the motor with different headers/mufflers before you put it in the car (Car Craft and Hot Rod do these tests frequently). The horse power and torque figures change and there are no wheels.
ponysarepretty
578
#15
  • Nov 28, 2005
  • #15
But for all intensive purposes RWHP is the figure you want to remember, because if your motor produces 1000 hp and 50% of it reaches the ground, its no better than a car that produces 700 hp and 70% of the hp reaches the ground.
jstreet0204
939
Winston Salem, NC
Nov 28, 2005
#16
  • Nov 28, 2005
  • #16
The 260 hp is SAE net hp which is rated at the flywheel with all accessories and exhaust systems intact. So the answer is, Yes you will gain FW hp. If the standard used was gross hp where no accessories and open manifolds were used then you wouldn't.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Nov 28, 2005
#17
  • Nov 28, 2005
  • #17
that is true its all on how much of it you can lay to the ground effectively :Word:
Mossberg
ATL, Shawty
Nov 28, 2005
#18
  • Nov 28, 2005
  • #18
I hope you like an extremely raspy exhaust note, because you just bought one!
streetstang03
unModerator
Dec 27, 2003
Nov 28, 2005
#19
  • Nov 28, 2005
  • #19
w/o a doubt.
BBK
ponysarepretty
578
#20
  • Nov 28, 2005
  • #20
its not all accessories, its all accessories now, but when the 260 was claimed it wasn't. also back then they could use some super slick lubricants, very cold inlet temps etc.
  • 3
1 of 3 Next Last
Engine Would you replace these OEM motor mounts?
  • 91GTstroked
  • Sep 21, 2026
Fox 5.0 Mustang Tech Oct 11, 2026
Potomus Pete
Airaid reduction sleeve?
  • BriansNSane
  • Dec 20, 2025
SN95 4.6L Mustang Tech Dec 20, 2025
BriansNSane
I
WTB/Trade 87-95 X-pipe and catbck
  • IconicSilverGT500
  • Apr 23, 2026
  • Exhaust Parts
Exhaust Parts Apr 23, 2026
IconicSilverGT500
I
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
