jstreet0204
coramprat said:But not above what the motor is already putting out unrestricted. If you have a motor dyno'd at 400 HP with the stock set-up then move to a more free flowing exhaust then yes you would gain but not more than you already had meaning without the stock exhuast your motor would dyno at 420 unrestricted for example.
What you are missing is the differnce between gross and net horsepower. Since 1972 manufacturers started using sae net hp for the fwhp numbers. This is measured with the full exhaust. Gross hp pre 1972 measured with unrestricted exhaust. The 260 hp rating was measured with the exhaust intact, so by removing the restrictions in the exhaust you will gain hp at the fw using the SAE net hp standard. Using the gross hp standard you would not. Your engine dyno example explained a gross hp measurement.
