Hydraulic clutch Master cylinder question
  • Thread starter Thread starter 65 Rustang
  • Start date Start date Oct 2, 2004
65 Rustang
  • Oct 2, 2004
Hi all,
I have a (hopefully) simple question about what size hyd clutch MC to use for my setup. It's a '65 with 289 and a Tremec 5.
What size would work best to give decent pedal effort and easy operation? 5/8? 3/4? 7/8? 1"?
I'm a bit new to the hydraulic idea, so your help is appreciated.
D
D.Hearne
11,730
south louisiana
Oct 2, 2004
  • Oct 2, 2004
The bigger, the better. The setup that came with my 89 Ranger had a 3/4 bore unit, now that I've swapped in the V8/Toploader 4 speed, I'm now using a 7/8 bore unit. Those are the only two sizes available to me for the Ranger.
jikelly
20+ Year Stangneter
Jul 9, 2003
872
53
99
Lubbock Tx
Oct 2, 2004
  • Oct 2, 2004
I used a 3/4 master cylinder and a 7/8 slave cylinder for may hydralic clutch setup.
WORTH
20+ Year Stangneter
Nov 18, 2002
2,166
44
98
Cape Cod, Ma.
Oct 3, 2004
  • Oct 3, 2004
65 Rustang said:
Hi all,
Hydraulics is simple, on the pump side,(master), the larger the bore, the harder you will have to push, but you will get the most travel out of the Slave.
So the smaller the bore, you will have to push easier, but the slave wont travel as far.
The exact opposite is true for the WORK,(SLAVE).
On the MASTER,You want the smallest bore that will give you the travel you need.
Example; If your clutch needs 100 lbs of pressure to move it,
WITH
1" bore master - 1" bore slave = you will have to push 100lbs pressure with your foot, and the slave will travel an inch for every inch of pedal movement.
2" bore master - 1" bore slave = you will have to push 200lbs pressure with your foot, but the slave will travel 2 inches for every inch of master travel.
1/2" bore master - 1" bore slave = you will have to push 50 lbs pressure but hte slave will only travel 1/2 inch per 1 inch of master travel.
Personally I like a hard clutch pedal, so I would go with the Largest Master.
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
t45 transmission How far does the clutch fork needs to travel to fully engage/disengage
  • SethG
  • Apr 28, 2025
  • Other Auto Tech
Other Auto Tech Apr 30, 2025
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
D
Brakes 1966 Mustang convertible 289, Auto - Disc brake conversion issues
  • DRGunn427
  • Feb 26, 2025
Classic Mustang Specific Tech Jul 23, 2026
All Stock93
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
