Hyper Pistons in 1992?
  • Thread starter Thread starter Henceforward
  • Start date Start date Mar 31, 2005
1 of 2 Next Last
Henceforward
The Avatar Master
485
  • Mar 31, 2005
I know that 1993 was the year for hyper pistons, but did Ford put them on Mustang GTs in 1992?
I was trying to find some info, but everywhere says 1993.
westridez
68
  • Mar 31, 2005
i herd they were in 92's to
HISSIN50
34
129
Mar 31, 2005
  • Mar 31, 2005
yep, in late-model year 92's.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Mar 31, 2005
  • Mar 31, 2005
How do you tell the difference between a hyper and a forged slug? My engines sitting in the garage so i'm just curious what I had in my 92. I'm gonna guess I had forged because when i had my dry n2o kit the a/f was 18:1 on the dyno and it didn't blow up
My 347 will have probe forged slugs
93 teal terror
971
62
69
Durham N.C.
Mar 31, 2005
  • Mar 31, 2005
black oil pan is hyper and grey is forged.....just hope no one switched pans on ya
Henceforward
The Avatar Master
485
  • Mar 31, 2005
Which months were late 1992? My car was built on 07/92, where would I fall?
And are Hyper pistons bad for any reason under 300 HP?
squeeeg
1,905
Michigan
Mar 31, 2005
  • Mar 31, 2005
D
Daggar
3,902
  • Mar 31, 2005
This may help:
http://www.mustanggt.org/gtchange.htm
About the only time I've heard of hyper pistons being much of a problem (on street machines) is with poorly tuned forced induction.
N
NUTCASE
187
  • Mar 31, 2005
from everyone I have talked to they all say the hypercrap is just as strong as the forged
its just that if you get a real bad detonation or something the forged will give a little(but still be damaged, you might make it home) but the hypers will shatter(leaving you stranded)
93 teal terror
971
62
69
Durham N.C.
Mar 31, 2005
#10
  • Mar 31, 2005
  • #10
I would venture thats late 92 but check your pan to make sure. They are fine for 300hp and even more as long as you dont have any detonation. Hypers are more brittle than forged and tend to have chuncks or holes in them when detonation occurs vs the forged that usually just get dented up a little bit.
btw thanks for the dancin monkey
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Mar 31, 2005
#11
  • Mar 31, 2005
  • #11
my stock hypers are doing fine with the S trim.
I did get a dyno/tune to ensure happiness.
I bet the block gives up before the pistons.
PS, I just put on the smaller pulley.
D
detroitmuscle99
10
#12
  • Mar 31, 2005
  • #12
hyperutectic pistons are not ment for any type of nitrous use, nitrous increases cylinder temps and a cast piston is very likely to meltdown, if you have the motor out go get a cheap set of Sealed Power Powerforged pistons, theyre less than $350 and a good moly ringset is like $90, if its a good motor dont worry about machine work (though i recommend it) just get standard stuff and put it back together. cheap insurance.
westridez
68
#13
  • Mar 31, 2005
  • #13
i was told hypers and boost dont mix not sure how tru that is
GroverDill
GoldMember
5,442
1,490
214
Demotte IN 46310
Apr 1, 2005
#14
  • Apr 1, 2005
  • #14
insurance for what a crappy tune..
im done, hyper pistons will turn to dust if you even say boost in front of them.....
Henceforward
The Avatar Master
485
#15
  • Apr 1, 2005
  • #15
Grey Pan! Forged! And I know it wasn't replaced.
I
Insane3D
310
#16
  • Apr 1, 2005
  • #16
My '92 GT is an early one..03/92, and it has a grey pan and forged pistons. I know for sure because I had to have one replaced...
88stangnut
155
westfield ,mass
Apr 1, 2005
#17
  • Apr 1, 2005
  • #17
I got a 93motor in my car, suppose now a 93 motor. It has a grey oil pan and it is a H.O motor. So prolly I got a early 92 instead of a 93 motor??? What do u guys think? If so that would be awsome lol
HISSIN50
34
129
Apr 1, 2005
#18
  • Apr 1, 2005
  • #18
88SN, when things are not known to be OEM, i would not read too much into the color of the pan.
and 93TT, thanks for posting that - i had never known how accurate that info was (pan color), and forgot about it altogether when i posted).
twolo4u2c2
5 Year Member
Apr 10, 2003
330
reading, PA
Apr 1, 2005
#19
  • Apr 1, 2005
  • #19
I put keith balck hypers in my 347 stroker...and acording to their tech they hold up fine with a good tune and 10psi boost making over 500hp. They have several employees using this combo.
93 teal terror
971
62
69
Durham N.C.
Apr 1, 2005
#20
  • Apr 1, 2005
  • #20
No problem, I've read it a few times and it has held up for every 87-92 amd 93 I've seen so Im pretty sure it works
1 of 2 Next Last
C
New member from NJ
  • Calyp5.0
  • Sep 25, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 25, 2026
General karthief
D
For Sale 1993 Mustang LX for parts or restore
  • diesel farmer
  • Oct 6, 2026
Fox Body Mustangs For Sale (1979-93) Oct 6, 2026
diesel farmer
D
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
Interior and Upholstery 87-93 Mustang Metal Side Headliner Trim Clips Upper Hatchback Coupe Door OEM 524
  • Noobz347
  • May 25, 2025
Fox 5.0 Mustang Tech May 25, 2025
