ok so i have been dealing with this problem for about 2 months now. It originally started when I replaced all the gaskets on the engine upper and lower intake valve cover throttle body EGR and IAC. When i put it back together it didnt want to run, at all. I thought simple vaccum leak so i checked all of the hoses on the manifold, they were all tight and in place. so then im thinking well maybe i have a leak in one of the gaskets so i take the ole butane torch out and start feeding butane into the seals to see if i could get the idle to surge, no luck still just rough as all can be. So now im thinking its the IAC. Well put a new one of those on from autozone, didnt change a thing. So next im thinking MAF, took that apart and then cleaned the filaments with an electro solvent, added a CAI with a conical K&N put it back together and still it wont idle. on top of all of that, the car doesnt want to drop RPMs like it should when i let off the gas.
here is exactly what it is doing so please anyone give me ideas....
when i first start the car up, I have to play with the gas or it will die, this takes a few minutes before i can even get the car staying running. After that point the idle will surge from 200-1600rpms and just keep doing it. Once i get about 5 miles on it and it gets a little heat into it, it then idles at about 500 but its really rough. The throttle response doesnt seem to be the same and the rpms are not very snappy at all, at least not from what it used to be.
My next theory is that somehow i have a bad vaccum to the fuel pressure reg and that its getting too much fuel on startup and part throttle. anyone please
